查看: 8464|回复: 9
BGK / MRT turbulence in Matlab
发表于 2013-5-30 11:44:44 | 显示全部楼层 |阅读模式
用的Smagorinsky model,  稍微简化了一下, 不过现有几个model似乎差别不大
clc
clear all
close all
x=100
y=200
tau=0.5*ones(x,y);
step=100
u0=0.05;
%% D2Q9 setup
ex(1,1,1:9)=[0 1 0 -1 0 1 -1 -1 1];
ey(1,1,1:9)=[0 0 1 0 -1 1 1 -1 -1];
c0=[0,0];c1=[1,0];c2=[0,1];c3=[-1,0];c4=[0,-1];c5=[1,1];c6=[-1,1];c7=[-1,-1];c8=[1,-1];
w(1,1,1:9)=[4/9,1/9,1/9,1/9,1/9,1/36,1/36,1/36,1/36];
%% setup solid boundary
[i,j]=meshgrid(1:y,1:x);
Solid=false(x,y);
Solid=Solid | (j-x/3).^2+(i-y/5).^2<(x/20)^2;
Solid=Solid | (j-x/2).^2+(i-y/2).^2<(x/20)^2;
Solid=Solid | (j-x/1.5).^2+(i-y/1.25).^2<(x/20)^2;
Solid(1,=true;
Solid(x,=true;
Fluid=~Solid;
Inlet=Fluid & i==1;
Outlet=i==y;
FluidAll=repmat(Fluid,[1,1,9]);
%% used for streaming indexing
Ind=reshape(1:x*y*9,x,y,9);
Ind(:,:,1+1)=circshift(Ind(:,:,1+1),c1);
Ind(:,:,2+1)=circshift(Ind(:,:,2+1),c2);
Ind(:,:,3+1)=circshift(Ind(:,:,3+1),c3);
Ind(:,:,4+1)=circshift(Ind(:,:,4+1),c4);
Ind(:,:,5+1)=circshift(Ind(:,:,5+1),c5);
Ind(:,:,6+1)=circshift(Ind(:,:,6+1),c6);
Ind(:,:,7+1)=circshift(Ind(:,:,7+1),c7);
Ind(:,:,8+1)=circshift(Ind(:,:,8+1),c8);
%% used for bounceback indexing
Blank=false(x,y);
SolidBB1=cat(3,Blank,Solid,Solid,Blank,Blank,Solid,Solid,Blank,Blank);
SolidBB2=cat(3,Blank,Blank,Blank,Solid,Solid,Blank,Blank,Solid,Solid);
temp=Ind(SolidBB1);Ind(SolidBB1)=Ind(SolidBB2);Ind(SolidBB2)=temp;
%% viscosity
Re=Inf;
Cs=5e-3
viscosity=u0*y/Re
tau0=3*viscosity+.5;
%% LES setup
exx(1,1,1:9)=[0 1 0 1 0 1 1 1 1];
eyy(1,1,1:9)=[0 0 1 0 1 1 1 1 1];
exy(1,1,1:9)=[0 0 0 0 0 1 -1 1 -1];
%% MRT setup
M=[  1    -4     4     0     0     0     0     0     0
     1    -1    -2     1    -2     0     0     1     0
     1    -1    -2     0     0     1    -2    -1     0
     1    -1    -2    -1     2     0     0     1     0
     1    -1    -2     0     0    -1     2    -1     0
     1     2     1     1     1     1     1     0     1
     1     2     1    -1    -1     1     1     0    -1
     1     2     1    -1    -1    -1    -1     0     1
     1     2     1     1     1    -1    -1     0    -1];
Mt=M';
M0=diag(1./sum(M.*M))*Mt;
S0=[0,1.63,1.14,0,1.92,0,1.92];
% S0=[0,1.64,1.54,0,1.7,0,1.7];
S0=ones(x*y,1)*S0;
%% UI control
restart = uicontrol('position',[20 20 80 20],'style','toggle','string','restart');
quit = uicontrol('position',[120 20 80 20],'style','toggle','string','close');
pausebutton = uicontrol('position',[220 20 80 20],'style','toggle','string','pause');
bgkmrt = uicontrol('position',[320 20 80 20],'style','toggle','string','switch to bgk');
while get(quit,'value') == 0
   set(restart,'value',0);
   set(pausebutton,'value',0);
    %% initial condition
    nTimestep=0;
    ux=zeros(x,y);
    uy=u0*ones(x,y);
    forcex=zeros(x,y);
    forcey(1:x,1:y)=2e-5;
    rho=ones(x,y);
    usq=ux.*ux+uy.*uy;
    c=(bsxfun(@times,ex,ux)+bsxfun(@times,ey,uy));
    density=bsxfun(@times,rho,w) .* bsxfun(@plus,1+3*c+4.5*c.*c,-1.5*usq);
    %% loop
    while get(restart,'value')==0 && get(quit,'value')==0
    while get(pausebutton,'value')==1 && get(restart,'value')==0 && get(quit,'value')==0
        set(pausebutton,'string','continue');pause(.01);end;set(pausebutton,'string','pause');%% restart and quit are volatile, so extra test is required
    %% calc macro
    rho=sum(density,3);
    ux=sum(bsxfun(@times,density,ex),3)./rho;
    uy=sum(bsxfun(@times,density,ey),3)./rho;
    %% forcing
    ux=ux+forcex./rho;
    uy=uy+forcey./rho;
    %% collision
    usq=ux.*ux+uy.*uy;
    density_eq=bsxfun(@times,rho,w) .* bsxfun(@plus,1+3*c+4.5*c.*c,-1.5*usq);
    density_delta=density_eq-density;
    moment=reshape(density,[x*y,9])*M;    ux_=ux(;uy_=uy(:);usq_=usq(:);
    moment_eq=bsxfun(@times,rho(:),[ones(x*y,1),-2+3*usq_,1-3*usq_,ux_,-ux_,uy_,-uy_,ux_.*ux_-uy_.*uy_,ux_.*uy_]);
    %% eddy viscosity with Smagorinsky model
    qxx=sum(bsxfun(@times,density_delta,exx),3);
    qyy=sum(bsxfun(@times,density_delta,eyy),3);
    qxy=sum(bsxfun(@times,density_delta,exy),3);
    q=sqrt(qxx.*qxx+qyy.*qyy+2*qxy.*qxy);
    tau=tau0+.5*(sqrt(tau0.*tau0+36*Cs*q)-tau0);
    %% collision cont'd
    if(get(bgkmrt,'value')==0)
        set(bgkmrt,'string','switch to bgk')
        S=[S0,1./tau(:),1./tau(:)];
    else
        set(bgkmrt,'string','switch to mrt')
        S=1./tau(:)*ones(1,9);
    end
    moment=moment+bsxfun(@times,moment_eq-moment,S);
    density_temp=reshape(moment*M0,[x,y,9]);
%     density_temp=density+bsxfun(@rdivide,density_delta,tau);
    density(FluidAll)=density_temp(FluidAll);
    %% stream & bounce back
    density=density(Ind);
    nTimestep=nTimestep+1;
    if(~mod(nTimestep,step))
        uxplot=uy.*Fluid;
        uyplot=ux.*Fluid;
        umag=sqrt(uxplot.*uxplot+uyplot.*uyplot);
        vmax=max(umag(:));
        vel=(256/vmax)*(umag);
        vor=curl(uxplot,uyplot)*20000+128;
        subplot(2,1,1)
        pcolor(vel)
        xlabel('Velocity')
        shading interp
        axis equal
        axis([1 y 1 x])
        title(sprintf('%d, tau=%f, u_m_a_x=%f, Vorticity_m_a_x=%f, Mass=%f',nTimestep,tau(x/2,y/5),vmax,max(vor(:)),sum(rho(:))));
        subplot(2,1,2)
        pcolor(vor)
        xlabel('Vorticity')
        shading interp
        axis equal
        axis([1 y 1 x])
        drawnow
    end
end
end
close(gcf)
 楼主| 发表于 2013-5-30 11:45:55 | 显示全部楼层
 楼主| 发表于 2013-5-30 15:29:14 | 显示全部楼层
更正: S0=[1,1.63,1.14,1,1.92,0,1.92];
外力才起作用
发表于 2013-5-30 16:13:17 | 显示全部楼层
Note: in LES, you need to use the special relationship between s_q and s_\nu so that the boundary locations is fixed.
[ 本帖最后由 luo@odu.edu 于 2013-5-30 16:51 编辑 ]
 楼主| 发表于 2013-6-1 14:56:26 | 显示全部楼层
回复 4# luo@odu.edu 的帖子
没有仔细研究......为什么呢?用宏观量算是否没这个问题?感谢罗老师回答
为什么3D下如果用 Lallemand & Luo 2000建议的we = 0, wej = 475/63, wxx = 0会出现流动方向上的抖动纹?
3D MRT/LBGK LES:
clc
clear all
close all
x=60
y=100
z=60
tau=0.5*ones(x,y,z);
step=1
u0=.1;
%% D3Q19 setup
ex(1,1,1,1:19)=[0 1 -1 0  0 0  0 1 -1  1 -1 1 -1 -1  1 0  0  0  0];
ey(1,1,1,1:19)=[0 0  0 1 -1 0  0 1 -1 -1  1 0  0  0  0 1 -1  1 -1];
ez(1,1,1,1:19)=[0 0  0 0  0 1 -1 0  0  0  0 1 -1  1 -1 1 -1 -1  1];
ee=[squeeze(ex),squeeze(ey),squeeze(ez)];
w0=1/3;w1=1/18;w2=1/36;
w(1,1,1,1:19)=[w0, w1,w1,w1,w1,w1,w1, w2,w2,w2,w2,w2,w2,w2,w2,w2,w2,w2,w2];
[j,i,k]=meshgrid(1:y,1:x,1:z);
Solid=false(x,y,z);
Solid=Solid | (i-x/2).^2+(j-y/5).^2+(k-z/2).^2<(x/10)^2;
Solid(1,:,=true;
Solid(x,:,=true;
Solid(:,:,1)=true;
Solid(:,:,z)=true;
Fluid=~Solid;
Inlet=Fluid & j==1;
Outlet=j==y;
FluidAll=repmat(Fluid,[1,1,1,19]);
Ind=reshape(1:x*y*z*19,x,y,z,19);
for n=1:18
    Ind(:,:,:,n+1)=circshift(Ind(:,:,:,n+1),ee(n+1,);
end
Blank=false(x,y,z);
SolidBB1=cat(4,Blank, Solid,Blank,Solid,Blank,Solid,Blank, Solid,Blank,Solid,Blank,Solid,Blank,Solid,Blank,Solid,Blank,Solid,Blank);
SolidBB2=cat(4,Blank, Blank,Solid,Blank,Solid,Blank,Solid, Blank,Solid,Blank,Solid,Blank,Solid,Blank,Solid,Blank,Solid,Blank,Solid);
%% viscosity
Re=2e5;
Cs=0.02
viscosity=u0*y/Re
%% LES setup
exx=ex.*ex;eyy=ey.*ey;ezz=ez.*ez;exy=ex.*ey;eyz=ey.*ez;exz=ex.*ez;
%% MRT setup
ex_=squeeze(ex);ey_=squeeze(ey);ez_=squeeze(ez);
ex2=ex_.*ex_;ey2=ey_.*ey_;ez2=ez_.*ez_;e2=ex2+ey2+ez2;e4=e2.*e2;
M=[ones(19,1),19*e2-30,(21*e4-53*e2+24)/2,ex_,(5*e2-9).*ex_,ey_,(5*e2-9).*ey_,ez_,(5*e2-9).*ez_,3*ex2-e2,(3*e2-5).*(3*ex2-e2),ey2-ez2,(3*e2-5).*(ey2-ez2),ex_.*ey_,ey_.*ez_,ex_.*ez_,(ey2-ez2).*ex_,(ez2-ex2).*ey_,(ex2-ey2).*ez_];
Mt=M';
S0=[0,1.19,1.4,1,1.2,1,1.2,1,1.2,1,1.4,1,1.4,1,1,1,1.98,1.98,1.98];
S=ones(x*y*z,1)*S0;
St=1./tau(:);
%% UI control
fastslow = uicontrol('position',[420 20 80 20],'style','toggle','string','fast simulation');
cbar = uicontrol('position',[520 20 80 20],'style','toggle','string','show colorbar');
    nTimestep=0;
    ux=zeros(x,y,z);
    uy=u0*ones(x,y,z).*Fluid;
    uz=zeros(x,y,z);
    forcex=zeros(x,y,z);
    forcey(1:x,1:y,1:z)=2e-5 *Fluid;
    forcez=zeros(x,y,z);
    rho=ones(x,y,z);
    usq=ux.*ux+uy.*uy+uz.*uz;
    c=bsxfun(@times,ex,ux)+bsxfun(@times,ey,uy)+bsxfun(@times,ez,uz);
    %% loop
    %% calc macro
    rho=sum(density,4);
    ux=sum(bsxfun(@times,density,ex),4)./rho;
    uy=sum(bsxfun(@times,density,ey),4)./rho;
    uz=sum(bsxfun(@times,density,ez),4)./rho;
    %% forcing
    ux=ux+forcex./rho;
    uy=uy+forcey./rho;
    uz=uz+forcez./rho;
    %% collision
    density_eq=bsxfun(@times,rho,w) .* bsxfun(@plus,3*c+4.5*c.*c,1-1.5*usq);
        moment=reshape(density,[x*y*z,19])*M;    rho_=rho(:);jx_=ux(:).*rho_;jy_=uy(:).*rho_;jz_=uz(:).*rho_;usq_=jx_.*jx_+jy_.*jy_+jz_.*jz_;
        moment_eq=[rho_,-11*rho_+19*usq_,3*rho_-5.5*usq_,jx_,-2/3*jx_,jy_,-2/3*jy_,jz_,-2/3*jz_,3*jx_.*jx_-usq_,-1.5*(jx_.*jx_-usq_/3),jy_.*jy_-jz_.*jz_,-.5*(jy_.*jy_-jz_.*jz_),jx_.*jy_,jy_.*jz_,jx_.*jz_,zeros(x*y*z,3)];
        moment_delta_1 =moment_eq(:,1 +1)-moment(:,1 +1);
        moment_delta_9 =moment_eq(:,9 +1)-moment(:,9 +1);
        moment_delta_11=moment_eq(:,11+1)-moment(:,11+1);
        moment_delta_13=moment_eq(:,13+1)-moment(:,13+1);
        moment_delta_14=moment_eq(:,14+1)-moment(:,14+1);
        moment_delta_15=moment_eq(:,15+1)-moment(:,15+1);
    else
    end
        S1=S(:,1+1);
        qxx=-(S1.*moment_delta_1/38+St.* moment_delta_9/2);
        qyy=-(S1.*moment_delta_1/38-St.*(moment_delta_9-3*moment_delta_11)/4);
        qzz=-(S1.*moment_delta_1/38-St.*(moment_delta_9+3*moment_delta_11)/4);
        qxy=-1.5*St.*moment_delta_13;
        qyz=-1.5*St.*moment_delta_14;
        qxz=-1.5*St.*moment_delta_15;
        q=reshape(sqrt(qxx.*qxx+qyy.*qyy+qzz.*qzz+2*(qxy.*qxy+qyz.*qyz+qxz.*qxz)),[x,y,z]);
    else
        qxx=sum(bsxfun(@times,density_delta,exx),4);
        qyy=sum(bsxfun(@times,density_delta,eyy),4);
        qzz=sum(bsxfun(@times,density_delta,ezz),4);
        qxy=sum(bsxfun(@times,density_delta,exy),4);
        qyz=sum(bsxfun(@times,density_delta,eyz),4);
        qxz=sum(bsxfun(@times,density_delta,exz),4);
        q=sqrt(qxx.*qxx+qyy.*qyy+qzz.*qzz+2*(qxy.*qxy+qyz.*qyz+qxz.*qxz));
    end
    %% collision cont'd
        St=1./tau(:);
        S(:,[9+1,11+1,13+1,14+1,15+1])=repmat(St,[1,5]);
        density_temp=reshape(moment*M0,[x,y,z,19]);
    else
    end
    if( get(fastslow,'value')==1 )
        set(fastslow,'string','slow simulation');
        step=10;
    else
        set(fastslow,'string','fast simulation');
        step=1;
    end
        uxplot=uy(:,:,z/2);
        uyplot=ux(:,:,z/2);
        rho_plot=rho(:,:,z/2);
        q_plot=q(:,:,z/2);
        tau_plot=tau(x/2,y/2,z/2);
        Mass=sum(rho(:));
        vmax=max(umag(:));
        vel=umag;
        vor=curl(uxplot,uyplot);
        subplot(2,2,1)
        pcolor(vel)
        if(get(cbar,'value')==1)
            set(cbar,'string','hide colorbar');
            colorbar
        else
            set(cbar,'string','show colorbar')
        end
        xlabel('Velocity')
        shading interp
        axis equal
        axis([1 y 1 x])
        title(sprintf('%d, tau=%f, u_m_a_x=%f, Vorticity_m_a_x=%f, Mass=%f',nTimestep,tau_plot,vmax,max(vor(:)),Mass));
        subplot(2,2,3)
        pcolor(vor)
            colorbar
        else
        end
        xlabel('Vorticity')
        shading interp
        axis equal
        axis([1 y 1 x])
        subplot(2,2,2)
        pcolor(rho_plot);
            colorbar
        else
        end
        xlabel('Rho')
        shading interp
        axis equal
        axis([1 y 1 x])
        subplot(2,2,4)
        pcolor(q_plot)
            colorbar
        else
        end
        xlabel('Local strain rate')
        shading interp
        axis equal
        axis([1 y 1 x])
        drawnow
    end
end
end
close(gcf)
发表于 2013-6-2 13:38:14 | 显示全部楼层
First, the parameters we suggested was based on LINEAR analysis, and the flow you are simulating is NONLINEAR. The linear analysis is only valid for linear STABILITY and nothing else.
Second, boundary conditions are a separate issue. Perhaps you can read one of my recent paper:
L.-S. Luo, W. Liao, X. Chen, Y. Peng, and W. Zhang.
Numerics of the lattice Boltzmann method: Effects of collision models on the lattice Boltzmann simulations.
Physical Review E 83(5):056710 (May 2011).
Which you can also download from my website.
发表于 2013-7-23 22:34:43 | 显示全部楼层
非常好的程序,非常好的楼主,谢谢!2D的已经用起来了
发表于 2014-3-14 16:59:39 | 显示全部楼层
谢谢楼主分享
感谢楼主分享,还有Luo老师的讲解,:)
发表于 2015-10-9 18:55:38 | 显示全部楼层
帮助很大 请问有没有C++代码实现的呢 新手学习
