查看: 1597|回复: 5
求助 fluent网格check
发表于 2013-6-16 17:33:40 | 显示全部楼层 |阅读模式
Mesh Check
Domain Extents:
   x-coordinate: min (m) = -7.071071e-001, max (m) = 0.000000e+000
   y-coordinate: min (m) = -9.999999e-001, max (m) = 0.000000e+000
   z-coordinate: min (m) = 0.000000e+000, max (m) = 1.000000e+000
Volume statistics:
   minimum volume (m3): 5.597537e-005
   maximum volume (m3): 1.063611e-003
     total volume (m3): 3.918408e-001
Face area statistics:
   minimum face area (m2): 5.597540e-004
   maximum face area (m2): 1.121395e-002
Checking number of nodes per cell.
Checking number of faces per cell.
Checking thread pointers.
Checking number of cells per face.
Checking face cells.
Checking cell connectivity.
Checking bridge faces.
Checking right-handed cells.
Checking face handedness.
Checking face node order.
Checking closed cells.
Checking contact points.
Checking element type consistency.
Checking boundary types:
Checking face pairs.
Checking wall distance.
Checking node count.
Checking nosolve cell count.
Checking nosolve face count.
Checking face children.
Checking cell children.
Checking storage.
Checking periodic boundaries.
   Periodic zone 20113: x-translation: min (m) = 0.000000e+000, max (m) = 7.071065e-001
                      y-translation: min (m) = -2.928936e-001, max (m) = 0.000000e+000
                      z-translation: min (m) = 0.000000e+000, max (m) = 0.000000e+000
Done.
WARNING: Mesh check failed.
发表于 2013-6-16 19:11:59 | 显示全部楼层
回复 1# qjx1806 的帖子
大神,你想问什么?
发表于 2013-6-16 22:48:13 | 显示全部楼层
网格质量真差,ogrid一下呢
 楼主| 发表于 2013-6-17 08:53:03 | 显示全部楼层
回复 2# chongdaql 的帖子
为什么check失败,没有报错warning,难道是网格质量,需要yblock
 楼主| 发表于 2013-6-17 09:32:06 | 显示全部楼层
回复 3# 5超7 的帖子
画了yblock,网格质量好了,也check失败,和原先一样
发表于 2013-6-17 10:05:49 | 显示全部楼层
回复 5# qjx1806 的帖子
重新关联一下试试看,Yblock以后再关联一下
