查看: 3386|回复: 10
right-handed left handed
发表于 2013-6-23 14:19:26 | 显示全部楼层 |阅读模式
画了个很简单的平面图,出现了warning :grid check failed ,好像是区域坐标系手型的问题。请教一下,到底是不是这个问题,如果是的话,怎么修改坐标系,fluent里面有没有repair命令可以直接修改?如果不是,那又是什么问题。
Reading "F:\2d_airfoil.msh"...
   44400 nodes.
   43956 quadrilateral cells, zone  9.
   87468 2D interior faces, zone 10.
     444 2D wall faces, zone 11.
     240 2D wall faces, zone 12.
     204 2D wall faces, zone 13.
Building...
     grid,
     materials,
     interface,
     domains,
     zones,
        airfoil_down
        airfoil_up
        far_field
        int_fluid
        fluid
     shell conduction zones,
Done.
Grid Check
Domain Extents:
   x-coordinate: min (m) = -1.500000e+001, max (m) = 1.599710e+001
   y-coordinate: min (m) = -1.503031e+001, max (m) = 1.502926e+001
Volume statistics:
   minimum volume (m3): 8.785914e-011
   maximum volume (m3): 8.255038e-001
     total volume (m3): 1.473622e+003
Face area statistics:
   minimum face area (m2): 4.140273e-007
   maximum face area (m2): 2.527767e+000
Checking number of nodes per cell.
Checking number of faces per cell.
Checking thread pointers.
Checking number of cells per face.
Checking face cells.
Checking bridge faces.
Checking right-handed cells.
Checking face handedness.
   Zone  12:   230 right-handed,    10 left-handed
Checking face node order.
Checking element type consistency.
Checking boundary types:
Checking face pairs.
Checking periodic boundaries.
Checking node count.
Checking nosolve cell count.
Checking nosolve face count.
Checking face children.
Checking cell children.
Checking storage.
Done.
WARNING: Grid check failed.
发表于 2013-6-23 15:47:04 | 显示全部楼层
换成双精度试试看
 楼主| 发表于 2013-6-23 22:35:16 | 显示全部楼层
回复 2# 5超7 的帖子
我用的就是双精度,2ddp
 楼主| 发表于 2013-6-23 22:37:04 | 显示全部楼层
回复 2# 5超7 的帖子
刚刚用了用单精度,也不行,一样的问题
发表于 2013-6-25 14:14:58 | 显示全部楼层
回复 4# skyfire 的帖子
是二维的吗?XY坐标平面作图的吗?
 楼主| 发表于 2013-6-26 07:35:49 | 显示全部楼层
回复 5# 5超7 的帖子
对的,二维,XY平面作图,不过现在已经改好了,我把网格节点数及排列方式重新布置了。
发表于 2013-6-26 08:36:31 | 显示全部楼层
回复 6# skyfire 的帖子
就是重新划分了网格是吧?
发表于 2013-6-26 08:57:09 | 显示全部楼层
回复 6# skyfire 的帖子
附面层第一层网格给的太小了
 楼主| 发表于 2013-6-27 12:47:00 | 显示全部楼层
回复 7# 5超7 的帖子
对的,可能就是因为附面层网格太小,网格数又比较少,所以网格变形比较大,作为一个没入门的菜鸟,能跟前辈讨论问题感到很荣幸啊
 楼主| 发表于 2013-6-27 12:48:35 | 显示全部楼层
回复 8# milaoshu 的帖子
我觉得也是,把网格布置的多了以后,附面层网格减得更小了,也没出问题。作为一个没入门的菜鸟,能跟前辈讨论问题感到很荣幸啊
发表于 2013-6-28 14:42:07 | 显示全部楼层
回复 9# skyfire 的帖子
一般出现这样的问题就是因为网格的长宽比太大了,这时候可以用双精度求解器尝试一下,如果还是不行的话,尝试增加第一层网格的高度,减小长宽比
