查看: 2026|回复: 4
请资深虫友帮忙解决,先谢过了!
发表于 2013-7-3 11:40:18 | 显示全部楼层 |阅读模式
问题如下,请资深虫友帮忙解决,先谢过了!
F:\simulation>gambit 1
Received exception: SIGSEGV (segmentation violation)
Please send the GAMBIT.272/jou and GAMBIT.272/trn files to your local
Fluent office or distributor.  Also send a message including any
relevant errors or warnings you see above in this window.  You may
wish to delete the temporary directory GAMBIT.272 after sending the
above files.
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
发表于 2013-7-3 13:45:00 | 显示全部楼层
回复 1# lgxy206 的帖子
装个icem吧   新版的ansys都有  装gambit还要配合exeed
发表于 2013-7-3 20:52:27 | 显示全部楼层
这里又不是小木虫~
发表于 2013-7-4 08:28:02 | 显示全部楼层
回复 3# onesupeng 的帖子
哈哈哈!有意思的回复!
 楼主| 发表于 2013-7-4 08:35:36 | 显示全部楼层
回复 2# 小七工作室 的帖子
ICEM不会用,所以只能gambit想办法了
