查看: 2438|回复: 0
求助:linux下fluent算例运行出错如何解决
发表于 2007-9-22 21:27:22 | 显示全部楼层 |阅读模式
我在远程登录集群机上运行fluent算例,出现如下错误:
[yjsy1@managenode bin]$ ./fluent 3d -g
/home/yjsy1/Fluent.Inc/fluent6.2.16/cortex/lnamd64/cortex.3.6.6 -f fluent -g (fluent "3d  -path/home/yjsy1/Fluent.Inc")
Loading "/home/yjsy1/Fluent.Inc/fluent6.2.16/lib/fluent.dmp.114-64"
Done.
Starting exec /home/yjsy1/Fluent.Inc/fluent6.2.16/lnamd64/3d/fluent.6.2.16 -cx managenode.cluster.seu.edu.cn:37855:37856
     Welcome to Fluent 6.2.16
     Copyright 2005 Fluent Inc.
     All Rights Reserved
Loading "/home/yjsy1/Fluent.Inc/fluent6.2.16/lib/flprim.dmp.1119-64"
Done.
Kill script file is /home/yjsy1/Fluent.Inc/bin/kill-fluent-managenode-17809
> file
/file> read-case
case file name [".cas"] "/home/yjsy1/Fluent.Inc/danguan13-2.cas"
Reading "/home/yjsy1/Fluent.Inc/danguan13-2.cas"...
   93021 tetrahedral cells, zone  2, binary.
   19806 triangular wall faces, zone  3, binary.
      72 triangular pressure-outlet faces, zone  4, binary.
      72 triangular velocity-inlet faces, zone  5, binary.
  176067 triangular interior faces, zone  7, binary.
   20896 nodes, binary.
   20896 node flags, binary.
Building...
     grid,
     materials,
     interface,
     domains,
        mixture
        air
        solid
        interaction
     zones,
        fluid  (air)
        wall  (air)
        outlet  (air)
        inlet  (air)
        default-interior  (air)
        fluid  (solid)
        wall  (solid)
        outlet  (solid)
        inlet  (solid)
        default-interior  (solid)
        default-interior
        inlet
        outlet
        wall
        fluid
     shell conduction zones,
Done.
/file> q
> solve
/solve> initialize
/solve/initialize>
compute-defaults/       initialize-flow         set-defaults/
init-flow-statistics    list-defaults
/solve/initialize> compute-defaults/
/solve/initialize/compute-defaults>
all-zones               pressure-outlet         wall
fluid                   velocity-inlet
/solve/initialize/compute-defaults> velocity-inlet
(inlet)
zone id/name [inlet] 5
(mixture solid air)
domain id/name [mixture] 1
/solve/initialize/compute-defaults> q
/solve/initialize> q
/solve> iterate
Number of iterations [1] 1000
File "danguan13-1.out" already exists.
Do you want to append the monitor data to it? [no] y
  iter continuity      u-air    u-solid      v-air    v-solid      w-air    w-solid   gt-solid          k    epsilon   vf-solid danguan13-     time/iter
Error: No graphics functions are available.
Error Object: ()
/solve>
求教如何解决。  谢谢
