查看: 3101|回复: 3
[讨论]fluent solver 中的这些个是什么意思呢?
发表于 2007-9-24 20:11:36 | 显示全部楼层 |阅读模式
那为大虾知道这个是什么意思呢?
FLUENT solver里有这个选项
GRADIENT OPTION
GREEN-GAUSS CELL BASED
GREEN-GAUSS NODE BASED
LEAST SQUARES CELL BASED
这代表什么意思,我该怎么选呢?大虾赐教
发表于 2007-9-25 10:40:24 | 显示全部楼层
看help,很有效的解决方法
发表于 2007-9-26 04:50:05 | 显示全部楼层
GRADIENT OPTION
GREEN-GAUSS CELL BASED==> gradients are computed with Green-Gauss integration in control volumes around cells
GREEN-GAUSS NODE BASED==>gradients are computed with Green-Gauss integration in control volumse around vertices
LEAST SQUARES CELL BASED=>gradients are computed with least-square in control volumes around cells.
These options can affect the accuracy of your results, but not much. I think least square is slower, but may be a little better. It is better to try different options  for the same case to see the differences.
 楼主| 发表于 2007-9-26 11:45:09 | 显示全部楼层
求Fluent帮助,那里有啊
