查看: 1872|回复: 1
icepak 并行运算请教,麻烦有service center 账号的xdjm帮忙
发表于 2007-10-19 09:48:48 | 显示全部楼层 |阅读模式
打算用icepak的并行运算功能,帮助中说
On a Windows machine, you must first follow steps 1-3 in the section Installing and Configuring Icepak Network Parallel on the Icepak User Services Center. . In the Remote execution parameters panel, you must then specify the full network path to the local installation of Icepak unless the local path has been mapped as a network drive on the remote machine or Icepak has been installed on the remote machine. In either of these exceptions, you can specify an appropriate drive letter as a part of the path.
麻烦有user service center 账号的帮忙拷贝一下 steps 1-3 in the section Installing and Configuring Icepak Network Parallel on the Icepak User Services Center
 楼主| 发表于 2007-10-22 14:45:35 | 显示全部楼层
没有用正版的么?
