查看: 3008|回复: 3
[求助]FLUENT中给出如下提示是否意味着缺少该数据
发表于 2007-12-3 08:49:36 | 显示全部楼层 |阅读模式
FLUENT中给出:
Material air:
  New property "Standard State Enthalpy" has been added.
  Selecting constant method for "Standard State Enthalpy" -- data required.
  New property "Standard State Entropy" has been added.
  Selecting constant method for "Standard State Entropy" -- data required.
  New property "Reference Temperature" has been added.
  Selecting constant method for "Reference Temperature" -- data required
这里有3个数据未知,是问这是否意味着需要用户自己来输入,我查看过,标准状态焓和标准状态熵的默认值为0,这当然是要自己输入,但是有些物理量,如Heat of Pyrolysis,虽然也说是未知,但FLUENT默认给出了非0的量,是问这是否意味着该量未知?
发表于 2007-12-3 12:22:36 | 显示全部楼层
给的是材料库里面的值,一般适用就不需要更改
 楼主| 发表于 2007-12-3 14:29:35 | 显示全部楼层
感谢版主的回答,我知道怎么处理了
发表于 2009-5-23 09:53:35 | 显示全部楼层
我也出现类似的情况,不知如何处理,请教楼主!
