查看: 4243|回复: 2
请问 surface heat transfer coef 和wall func.heat tran.coef 这两者有何区别?
发表于 2008-1-14 17:33:48 | 显示全部楼层 |阅读模式
我要计算对流换热系数,report type中选integral还是Area-Weighted Average; 是选 Surface Heat Transfer Coef 还是Wall Func. Heat Tran. Coef.  ?还有用surface heat transfer coef 是负的,而用wall 是正的?
                        Integral
     Surface Heat Transfer Coef.         (w/m2-k)(m2)
                            wall           -662.69794
                            wall           -427.54708
     Wall Func. Heat Tran. Coef.             (w/m2-k)
                            wall            42.758331
                        Integral
     Wall Func. Heat Tran. Coef.         (w/m2-k)(m2)
                            wall            66.275411
发表于 2011-1-8 13:32:37 | 显示全部楼层
回复 1# hanhuier 的帖子
楼主知道答案了么?
发表于 2012-8-21 14:29:22 | 显示全部楼层
