查看: 1646|回复: 1
[求助]GAMBIT启动问题 谢谢
发表于 2008-1-22 14:42:59 | 显示全部楼层 |阅读模式
各位大侠好,能否帮我分析一下gambit启动过程中遇到的问题,谢谢!
启动时,提示语如下:exceed是6.2的。
Locating Exceed installation ...
gambit failed in locating Exceed installation on your system.
Please try to start Exceed manually before you run gambit.
Starting C:\Gambit\gambit2.3.16\ntx86\gambit.exe -device open -id default_id2668 -new  ...
Gambit build SP2006032921.
Warning : The current transport does not permit the attempted TCPIP connection.
TRANS(SocketINETGetAddr): tnamebysocket() failed
TRANS(SocketINETConnect): TRANS(SocketINETGetAddr) () failed
TRANS(Open): transport open failed for tcp/n050506:0
Unable to open display
发表于 2008-1-22 22:17:36 | 显示全部楼层
[求助]GAMBIT启动问题 谢谢
好像是你的exceed出了问题
