查看: 3994|回复: 2
求助ICEM画网格时按照教程上生成面网格时出错
发表于 2013-8-3 16:52:39 | 显示全部楼层 |阅读模式
按照教程上画3D Pipe Junction网格,生成面网格的时候回弹出mesh has not generate的窗口,网格也生成不了。后来干脆放弃面网格,直接生成体网格,出现了错误
ailed to allocate 13544608 points (433427456 bytes)
A serious internal error has occurred.
Continuing to work may be dangerous.
Please save your work as soon as possible
and use a previous copy of your work.
If you cannot proceed without getting this
message please contact technical support.
The following message was designed to aid developers fix the problem:
mesh_super_blocks: Failed to allocate memory
Done recompute
请知道的前辈指导一下,谢谢!
发表于 2013-8-4 07:23:14 | 显示全部楼层
可能是内存不足吧
 楼主| 发表于 2013-8-5 19:07:58 | 显示全部楼层
回复 2# shineway 的帖子
网格数量太多?
但是调小了也不行。
