查看: 2243|回复: 2
3D cylinder with 0 degree transition fillet
发表于 2013-11-29 18:43:58 | 显示全部楼层 |阅读模式
Meshed as multiblock all hex using ICEM CFD.
Can be easily extended to compressor or turbine
blades with 0 transition angle fillets.
mesh1
mesh1
 楼主| 发表于 2013-11-29 18:45:06 | 显示全部楼层
cross section view of the volume mesh along the centre line.
 楼主| 发表于 2013-11-29 18:46:51 | 显示全部楼层
回复 2# flowinflow 的帖子
Geometry and blocking files are available upon request: xushenren@gmail.com
[ 本帖最后由 flowinflow 于 2013-11-29 18:48 编辑 ]
