查看: 3194|回复: 0
新手请教个chemkin的表面反应问题
发表于 2014-1-17 22:18:04 | 显示全部楼层 |阅读模式
chemkin刚起步的菜鸟向神人请教一个表面反应的问题,希望能得到帮助,十分感谢!
例如木炭的表面燃烧
C(s)+ O2 = CO + O (s)
O (s) + 2 C (B) = CO + C(s)
---C(s) , O(s)是surface active sites, C (B) 是bulk.
该如何确定一下表面 active sites的密度,热力参数, 以及bulk的热力参数。
A Tutorial on Chemkin(http://wenku.baidu.com/view/35a270b369dc5022aaea005e.html)这个里面说把不知道的sites的热力参数都弄成0, 我试了不行啊。
-----------------------input 的列表
SITE/CARBON_SURFACE/    SDEN/1.17E-9/
C(S)  O (s) END
BULK  C(B) /9.25/ END
THERMO
300.0 1000.0 3000.0
C(s)                C   1                    I  0300.00   1000.00  3000.00     1
0.00000000E+00 0.00000000E+00 0.00000000E+00 0.00000000E+00 0.00000000E+00    2
0.00000000E+00 0.00000000E+00 0.00000000E+00 0.00000000E+00 0.00000000E+00    3
0.00000000E+00 0.00000000E+00 0.00000000E+00 0.00000000E+00                   4
O(s)                O   1                    I  0300.00   1000.00  3000.00     1
C(B)                C   1                    I  0300.00   1000.00  3000.00     1
END
REACTIONS
O (s) +  C (B)  +  C (B)= CO + C(s)
END
output 关于表面的结果就是
SYNTAX ERROR, OR ILLEGAL VALUE
      Error...fit temperatures are not in ascending order;values found are:
  0.000000000000000E+000   3000.00000000000        1000.00000000000
SITE: CHAR_SURFACE               0.117E-08 moles/cm**2
3. C(S)             0.0000E+00                   1            0         0         0         0         0
      Error...no thermodynamic properties for species C(S)
4. O(S)             0.0000E+00                   1            0         0         0         0         0
      Error...no thermodynamic properties for species O(S)
BULK: BULK1
5. C(B)             0.0000E+00 9.250E+00 g/cm**3              0         0         0         0         0
      Error...thermodynamics temperatures must be in order...
      SURFACE REACTIONS CONSIDERED                      A        b        E
   1. C(S)+O2=>CO+O(S)                              2.20E+14    0.0      167.4
      Error...reaction does not balance in elements/mass...
   2. O(S)+C(B)+C(B)<=>CO+C(S)                      1.00E+08    0.0        0.0
该如何调整下啊?请大神指导下菜鸟。谢谢啦!
[ 本帖最后由 meng9019 于 2014-1-17 15:31 编辑 ]
