查看: 1215|回复: 0
Solar load model and ambient temperature
发表于 2014-2-1 08:29:11 | 显示全部楼层 |阅读模式
I have applied solar load model in my case
I wonder if I should patch the ambient temperature in the air domain
My doubt is that if I set the ambient temperature in 40 degree and the solar ray applied in the air domain and internal structure, I guess the ambient temperature will sharply rise after running
Is my comment correct or not
Look forward to hearing from you
Thanks
