查看: 1511|回复: 1
fluent6.3安装后无法正常使用,有没有人可以帮忙以下?
发表于 2014-2-5 15:54:56 | 显示全部楼层 |阅读模式
启动后出现下面代码
Server node is down or not responding
See the system adminstrator about starting the server, or
make sure the you're referring to the right host (see LM_LICENSE_FILE)
Feature:       fluent
Hostname:      "
License path:  D:\Fluent.Inc\license
tx86\..\license.dat
FLEXlm error:  -96,7.  System Error: 11001 "WinSock: Host not found (HOST_NOT_FOUND)"
available at "www.macrovision.com".
发表于 2014-2-10 15:46:59 | 显示全部楼层
修改license文件中的计算机名
