查看: 1796|回复: 11
How to use Gambit create "Mesh Edge" for circle o&#1
发表于 2008-4-16 22:10:20 | 显示全部楼层 |阅读模式
Hi,
Does anyone knows how to mesh edge for circle, oval or irregular boundary using Gambit?
Thank...
发表于 2008-4-16 22:25:29 | 显示全部楼层
How to use Gambit create "Mesh Edge" for circle or oval shape boundary
你是要画圆形或者椭圆形的面网格吧?不仅是边吧?
 楼主| 发表于 2008-4-16 22:31:06 | 显示全部楼层
yes..
I know how to mesh edge and mesh face for rectangle boundary..
but I need to mesh edge and mesh face a human heart boundary.
Can anyone help me please?
Thank you.[br][br][以下内容由 jpopsurfer 在 2008年04月16日 10:57pm 时添加] [br]
I mean i need to know how to mesh edge and face for a human heart shape boundary..
发表于 2008-4-17 14:58:18 | 显示全部楼层
你遇到什么困难了吗?用Gambit做面网格是很简单的。
发表于 2008-4-17 17:23:43 | 显示全部楼层
你可以用非结构的网格来画不规则面上的网格。
比如,在生成面网格时,Elements项选Tri或者Quad,Type项选Pave。试情况而定吧。
发表于 2008-4-17 18:10:33 | 显示全部楼层
直接mesh面
 楼主| 发表于 2008-4-17 22:25:32 | 显示全部楼层
You mean no need to mesh edge for a 2D human heart?
Just Mesh Face?
Under Elements, I set Quad/Tri and under Type, I set to Pave.
What about interval count? I set to 5 and click apply, but the meshing is very very slow...
Pls help me.. Thank you.
发表于 2008-4-17 23:02:56 | 显示全部楼层
You may choose Tri+Pave instead, as the interval count, just set to the number you feel enough.
 楼主| 发表于 2008-4-18 07:19:41 | 显示全部楼层
I heard that for laminar flow, I need to mesh the face as Quad.. Is this correct?
May I asked how many interval counts is enough?
发表于 2008-4-18 09:20:19 | 显示全部楼层
interval counts是根据你的流场而定的
先可以设定一个较小的值,画好网格计算看看边界处相应的y+值,小于100就可以接受,不行就调整interval counts大一些
发表于 2008-4-18 10:03:06 | 显示全部楼层
interval counts的设置与你的直径有关,不宜设得太小,可先设为直径的1/10试试
 楼主| 发表于 2008-4-18 19:15:39 | 显示全部楼层
I am using interval counts of 10 now. The meshing takes a long time when I set to Quad/Tri and Pave. Am I doing the right thing? I need to import into Fluent later.
