查看: 2316|回复: 3
layering 动网格模拟
发表于 2014-4-27 16:01:58 | 显示全部楼层 |阅读模式
模拟潜艇在水中运动,水中物体对潜挺的影响,为什么潜艇计算的力矩越来越大那里出现问题了 求高手指教 给点提示
发表于 2014-4-27 21:33:33 | 显示全部楼层
回复 1# 奥特曼 的帖子
把你的例子发上来啊 要不然怎么知道你什么问题
 楼主| 发表于 2014-4-27 21:43:07 | 显示全部楼层
回复 2# milaoshu 的帖子
#include <stdio.h>
#include "udf.h"
static FILE *fp;
static real force[3];
static real M[3];
static real cg[3];
static  int id1=21;
DEFINE_CG_MOTION(go_others, dt, cg_vel, cg_omega, time, dtime)
   real a=1;
   real cgvel=0.0;
   real velo;
  /* reset velocities */
  NV_S (cg_vel, =, 0.0);
  if (!Data_Valid_P ())
    return;
  velo =a;
  Message ("\nUDF auv: time = %f, dtime = %f, y_vel = %f, ", time, dtime, velo);
  cg[1]=0.0; cg[0]=0.0;
    if(time==0&&time<0.1)
     cg[0]=0;
     cg[1]=0;
     cg[2]=0;
  cg_vel[0] =velo;
  cg[0]=cg[0];
  cg[2]=cg[2];
  cg[1]=cg[1];
if(time>=0.1)
  cg[0]=cg[0]+velo*(time-0.1);
  cg[2]=cg[2];
  cg[1]=cg[1];
  Message ("M=%f cg[0]=%f cg[2]=%f\n", M[1],cg[0],cg[2]);
   node_to_host_real_1(cgvel);
   node_to_host_real(cg_vel,ND_ND);
DEFINE_CG_MOTION(go_auv, dt, cg_vel, cg_omega, time, dtime)
   Thread *t = DT_THREAD (dt);              /* pointer to a thread */
   Domain *d;                               /* pointer to collection of all threads */
   Thread *t1;
   real a=1;
   real cgvel=0.0;
   real velo;
    return;
  velo =a;
     cg[0]=0;
     cg[1]=0;
     cg[2]=0;
         fp=fopen("drag.txt","w");
         fclose(fp);
    fp=fopen("drag.txt","a");
  cg_vel[0] =velo;
  d=Get_Domain(1);
  t1=Lookup_Thread(d,id1);               /*Thread Pointer for Zone ID*/
  Compute_Force_And_Moment(d,t1,cg,force,M,1);
  cg[0]=cg[0];
  cg[2]=cg[2];
  cg[1]=cg[1];
if(time>=0.1)
  cg[2]=cg[2];
  cg[1]=cg[1];
  fprintf(fp,"time=%f M=%f drag=%f force-z=%f cg[0]=%f cg[2]=%f\n",time,M[1],force[0],force[2],cg[0],cg[2]);
  fclose(fp);
定义潜艇在水中前进,力矩从-2一直增到+4  实际定常计算力矩是-3, 这是udf
发表于 2014-6-27 23:58:04 | 显示全部楼层
力也在变吗?是不是你力矩参考点的问题?
