查看: 2401|回复: 1
叶片几何质量有些粗糙,B2B 时出现错误如何破???
发表于 2014-5-4 20:37:19 | 显示全部楼层 |阅读模式
warning during row 1 generation systerm .detects geometry problem in main blade definition:tangent break or joined control points. use blade gemometry check menu to detect the problem location and make a data reduction
 楼主| 发表于 2014-5-4 20:38:53 | 显示全部楼层
回复 1# lhlvek 的帖子
大家指点下,在线等,这个blade gemometry check menu在哪里?
