查看: 5128|回复: 2
求助一个关于格子声速的问题
发表于 2014-5-12 15:30:59 | 显示全部楼层 |阅读模式
最近在看一些格子Boltzmann方法的书,包括郭照立老师和一本国外老师写的书,发现上面在介绍到D2Q9模型的时候都说格子声速Cs的平方等于1/3,我只是比较好奇为什么这里格子声速的平方要等于1/3呢,其他速度离散模型又是另外的值呢?
如果有相关的参考资料最好啦,谢谢~
发表于 2014-5-12 20:20:15 | 显示全部楼层
回复 1# tenitsu 的帖子
The speed of sound is defined as the propagation speed of density fluctuations. Thus, one can DERIVE this speed based on a model. More specifically, one can derive linearized hydrodynamic equations to figure out the speeds of all waves and dissipation. For D2Q9 model, you can see how this is done in the following paper:
P. Lallemand and L.-S. Luo.
Theory of the lattice Boltzmann method: Dispersion, dissipation, isotropy, Galilean invariance, and stability.
Physical Review E 61:6546-6562 (June 2000).
You can download this paper from my website in case you cannot get it else where.
-- LSL
 楼主| 发表于 2014-5-12 22:26:23 | 显示全部楼层
回复 2# luo@odu.edu 的帖子
谢谢!
