查看: 1630|回复: 1
大家帮看下,这是不是说明我网格有问题啊。
发表于 2008-5-9 20:09:53 | 显示全部楼层 |阅读模式
782908 nodes.
  176632 mixed wall faces, zone  3.
     102 mixed outflow faces, zone  4.
     108 mixed velocity-inlet faces, zone  5.
     108 mixed velocity-inlet faces, zone  6.
     108 mixed velocity-inlet faces, zone  7.
2002762 mixed interior faces, zone  9.
  696944 hexahedral cells, zone  2.
Building...
     grid,
Note: Separating wall zone 3 into zones 3 and 1.
      wall -> wall (3) and wall:001 (1)
Removing 918 unreferenced faces, zone 1.
Warning: Number of nodes read (782908) does not match number referenced (782500).
Resetting counter to match the number referenced.
     materials,
     interface,
     domains,
     zones,
Skipping zone wall:001 (not referenced by grid).
default-interior
songfeng1
songfeng2
songfeng3
paifeng
wall
fluid
     shell conduction zones,
Done.
发表于 2008-5-10 17:18:17 | 显示全部楼层
检查一下是不是所有的体都画上网格了?
