查看: 5961|回复: 0
fluent 15.0迭代不久后莫名出错终止
发表于 2014-9-12 20:25:32 | 显示全部楼层 |阅读模式
这两天用服务器上的fluent 15.0(linux_x64)算一个多相流,但是每次迭代到一定步数(每次步数不一定相同),fluent就会自动终止,并出现如下报错:
===============Message from the Cortex Process================================
Fatal error in one of the compute processes.
MPI Application rank 12 killed before MPI_Finalize() with signal 9
Node 13: Process 30458: Received signal SIGTERM.
Node 8: Process 30453: Received signal SIGTERM.
Node 10: Process 30455: Received signal SIGTERM.
Node 15: Process 30460: Received signal SIGTERM.
Node 9: Process 30454: Received signal SIGTERM.
在cortexerror.log里,显示如下错误:
Error [cortex] [time 9/12/14 19:14:3] Cortex received a fatal signal (SEGMENTATION VIOLATION).
1000000: fluent(CX_Primitive_Error+0x1ca) [0x4fdb8a]
1000000: fluent() [0x4fdfea]
1000000: /lib64/libc.so.6(+0x32bf0) [0x7f7b92ad2bf0]
1000000: /lib64/libc.so.6(+0x3575a) [0x7f7b92ad575a]
1000000: /lib64/libc.so.6(+0x35845) [0x7f7b92ad5845]
1000000: fluent() [0x4fc8b0]
1000000: /lib64/libc.so.6(__select+0x33) [0x7f7b92b70cc3]
1000000: fluent(listen_input+0xef) [0x50322f]
1000000: fluent() [0x5033e9]
1000000: fluent(lreadf+0x42) [0x5d9312]
1000000: fluent(eval+0x456) [0x5d4836]
1000000: fluent(eval+0xde4) [0x5d51c4]
1000000: fluent(eval+0x893) [0x5d4c73]
1000000: [0x7f7b8ae62800]
注:前几天都可以正常计算的,并且昨天问题出现后我已经重装了ansys 15.0,然后把服务器节点也重新启动了,但是还是会出现这种问题,所以想求助下论坛里的老师和同学。
在此表示感谢!
waouyouy
