查看: 4532|回复: 6
计算出错,提示出现负温度,什么原因
发表于 2014-11-19 14:25:27 | 显示全部楼层 |阅读模式
>>> rho =   -901.23     at (     2,     18,      1)
>>> rho =  -0.16473E+18 at (     6,     22,      1)
>>> rho =  -0.22294E+17 at (     5,     23,      1)
>>> rho =  -0.17311E+19 at (     6,     23,      1)
>>> rho =  -0.23291E+19 at (     7,     23,      1)
>>> Additional negative density messages have been suppressed....
[WARNING]: (getpress) Negative or zero temperature encountered.
            Cell #        1027  has T =   -5146.13984678649
            Reset to original value:    319.191444763736
            Cell #        1255  has T =   -30.2951141472491
            Reset to original value:    321.227044000696
            Cell #        1262  has T =   -274.772726642636
            Reset to original value:    321.255480582217
            Cell #        1293  has T =   -40213.0815959950
            Reset to original value:    320.923845300018
            Cell #        1300  has T =   -381.028192249829
            Reset to original value:    320.961144571770
            (getpress) Additional negative-temperature messages suppressed...
    48     116   2.6676E+00   7.6823E-04   8.6874E+12   1.5051E-08   1.3555E-05   3.1621E+03
    49     116   2.5133E-01   3.5435E-05   1.2977E-04   2.6586E-06   2.0747E-05   3.1623E+03
>>> rho =  -0.81964E+31 at (     1,      1,      1)
[ERROR]: (upflim) Negative density at cell            1
--- Program Execution Terminated due to Error.
 楼主| 发表于 2014-11-19 16:18:30 | 显示全部楼层
怎么没人回复,目前来看减小终止CFL number用点用,再算算看
发表于 2014-11-19 18:10:50 | 显示全部楼层
请稍安勿躁,大家都有自己的工作,不一定能按照你的想法及时回复你。
你给的信息只说明了负温产生,但是fastran产生负温基本上和设置不当有关,所以如果要解决问题,可能需要给出dtf文件(或者说明具体设置)
 楼主| 发表于 2014-11-20 13:32:56 | 显示全部楼层
BC TYPE:inflow/outflow里面的static pressure是指的当地绝对压力吗?我给的101325pa。
三维机翼扰流,稳态SA模型,Ma=0.7; FDS first order;Final CFL=0.2;Time integration--implicit non-iterative。算了600步,残差还没下降一个数量级。应该修改什么加速收敛呐?
发表于 2014-11-24 10:36:45 来自手机 | 显示全部楼层
三维机翼扰流,稳 ...
首先边界条件没有设置错误,但静压可能要根据实际情况换算出来,而不是直接给101325Pa。收敛性和收敛快慢可能与网格质量和cfl数有关,请关注一下这两个方面。
 楼主| 发表于 2014-11-24 12:04:42 | 显示全部楼层
好,我改一下,谢谢指点
发表于 2014-12-17 21:50:48 | 显示全部楼层
请问楼主,你的负密度问题是如何解决的?我也出现的同样的情况。。。。然后我减小了初始CFL数和终止CFL数,倒是可以算了,
残差下降不明显,我觉得应该继续调整CFL数吧。请问楼主,还有做其他的修改吗?
