查看: 3124|回复: 0
Fluent switch from implicit to explicit...
发表于 2015-4-23 18:27:18 | 显示全部楼层 |阅读模式
I'm running steady state simulation using density-based solver in ANSYS-Fluent
for a 2D airfoil in buffet condition.
I found that when I switch from implicit time stepping to explicit multigrid time stepping,
the FAS cycle always re-initialise the solution, rather than continue with the semi-converged
solution from the implicit time stepping.
Anyone has a clue how to avoid the re-initialisation?
Cheers,
flowinflow
