查看: 8927|回复: 17
高手会诊 FLUENT求解过程中 老是发散,为什么?
发表于 2003-8-10 13:41:53 | 显示全部楼层 |阅读模式
    我把courant number 由原来的 1.0 变为现在的0.1 她还是发散,请问这是怎么回事?courant 可以再设小点吗?
详细显示如下:
iter continuity x-velocity y-velocity z-velocity     energy        nut     time/iter
0.
     1 1.0000e+00 1.0000e+00 1.0000e+00 1.0000e+00 1.0000e+00 3.2247e-03  2:30:16   49
0.
     2 7.8948e-01 9.7079e-01 1.0000e+00 1.0000e+00 7.9025e-01 1.1996e-03  2:21:07   48
0.
time step reduced in 12 cells
     3 1.0000e+00 1.0000e+00 1.0000e+00 1.0000e+00 1.0000e+00 4.5671e-04  2:11:51   47
0.
time step reduced in 20 cells
absolute pressure limited to 5.000000e+06 in 2 cells on zone 2
temperature limited to 5.000000e+03 in 4 cells on zone 2
     4 1.0000e+00 1.0000e+00 1.0000e+00 1.0000e+00 1.0000e+00 1.8341e-04  2:04:05   46
0.
time step reduced in 24 cells
absolute pressure limited to 5.000000e+06 in 5 cells on zone 2
temperature limited to 5.000000e+03 in 5 cells on zone 2
     5 1.0000e+00 1.0000e+00 1.0000e+00 1.0000e+00 1.0000e+00 8.1697e-05  1:57:31   45
0.
time step reduced in 67 cells
absolute pressure limited to 5.000000e+06 in 11 cells on zone 2
temperature limited to 5.000000e+03 in 12 cells on zone 2
     6 1.9056e+00 4.7280e+00 4.7311e+00 4.0454e+00 1.1653e+00 4.3016e-05  1:51:52   44
0.
time step reduced in 126 cells
absolute pressure limited to 1.000000e+00 in 3 cells on zone 2
absolute pressure limited to 5.000000e+06 in 57 cells on zone 2
temperature limited to 5.000000e+03 in 72 cells on zone 2
     7 4.1472e+00 2.0018e+01 8.0736e+00 6.9799e+00 5.1762e+00 2.8201e-05  1:47:06   43
0.
time step reduced in 168 cells
absolute pressure limited to 5.000000e+06 in 130 cells on zone 2
temperature limited to 5.000000e+03 in 166 cells on zone 2
     8 8.5241e+00 1.9146e+02 4.3919e+01 3.7610e+01 2.6551e+01 2.6893e-05  1:42:52   42
0.
time step reduced in 156 cells
absolute pressure limited to 1.000000e+00 in 5 cells on zone 2
absolute pressure limited to 5.000000e+06 in 240 cells on zone 2
temperature limited to 5.000000e+03 in 288 cells on zone 2
Error: Floating point error: invalid number
发表于 2003-8-10 14:35:38 | 显示全部楼层
发散是正常的,原因不计其数,我所碰到的原因有以下几个方面:
边界条件的处理
初始条件的处理
模型的处理
差分格式的处理
湍流模型的选取
问题的求解步骤
这些问题都要求具有较多的基础知识才可能发现真正的问题所在,尤其是对于耦合求解器来说,采用预处理矩阵来处理不可压流动或者低可压流动是特别容易发散。
发表于 2003-8-11 18:04:50 | 显示全部楼层
有时也要碰运气
发表于 2003-8-11 18:15:13 | 显示全部楼层
计算发散的处理方法可以用courant number的方法解决,但是也不绝对。用courant number能够解决的问题是计算格式的稳定性不好的算例,而计算中采用的物理模型、边界条件、初始条件等的设置有误也可以导致计算发散,所以在调整CFL数无效的情况下,应该考虑是否在模型设置过程中是否有不合理的地方,改正后一般是可以获得收敛解的。
发表于 2003-8-11 18:58:28 | 显示全部楼层
网格上的原因,也要找找,有时四面体网格会存在极差的网格,计算在这里会发生伪扩散。
发表于 2003-8-12 10:33:18 | 显示全部楼层
首先要保证划分的网格、边界条件合理,如果不收敛可以考虑改一下courant number ,但是一般默认值比较好,通常不应该做大的改动。除此之外,改一下差分格式,比如采用piso等
 楼主| 发表于 2003-8-13 15:20:24 | 显示全部楼层
   谢谢诸位!
发表于 2003-8-13 18:00:27 | 显示全部楼层
小弟有个极菜的问题,请问courant number 在那里设
 楼主| 发表于 2003-8-13 18:53:30 | 显示全部楼层
  sovler——contral——solution
发表于 2003-8-13 21:37:50 | 显示全部楼层
solve--controls--solution
没有啊
发表于 2003-8-13 21:41:03 | 显示全部楼层
你们设什么计算模型
发表于 2003-8-13 22:09:23 | 显示全部楼层
对于不可压流体,尽可采用segerated 方法,而可压流体采用coupled,此时才有库朗数。那对于采用segerated的方法的,计算结果不收敛该如何??
边界条件总是一定的吧
发表于 2003-8-14 01:42:58 | 显示全部楼层
有时候计算不收敛是初始流场设置比较粗糙引起的,可以考虑用改变初始流场的方法解决问题。
发表于 2003-8-14 08:47:30 | 显示全部楼层
计算不收敛的原因有很多,特别是三维计算问题,所以在建模、划分网格、设定初始条件……每一步都要注意!
发表于 2003-8-14 13:58:45 | 显示全部楼层
初始条件怎么设
