查看: 1341|回复: 3
two tips for Fluetn batch run on linux
发表于 2003-11-15 06:57:44 | 显示全部楼层 |阅读模式
1. obtain intermediate results without terminate the iteration
the owner of the process can create a file /tmp/check-fluent, this will cause Fluent to write to file before proceed to the next iteration
2.terminate the iteration by create a file /tmp/exit-fluent
I am not sure how to do it on Windows, anybody knows?
发表于 2003-11-15 16:01:22 | 显示全部楼层
As I know, there is no difference between Fluent runing in Window or LINUX.
1. you want to auto save the date file ? Just use "aoto save"
2. I can't understand what you want to do.
 楼主| 发表于 2003-11-16 00:43:53 | 显示全部楼层
You can certainly use auto-save in the journal file, however, what I said is applied to situations that auto-save has not been set in the journal file, and you want to save the results of the CURRENT iteration!
发表于 2003-11-16 10:40:54 | 显示全部楼层
I can't understand, just save?
