查看: 3309|回复: 5
学GAMBIT手记
发表于 2002-9-2 22:38:01 | 显示全部楼层 |阅读模式
近来在学GAMBIT,现把学习的笔记发上来。希望对大家有帮助,表表心意,同时也是对这个论坛的支持!今天把USER'S GUIDE 一章发上来,以后陆续会把其他的发上来
                                                     USER'S GUIDE
{1}introduction
一.format
1.Graphic format
1)Control elements
allow you to perform operations such as executing actions and operations, choosing from among a given set of options,
and inputting alphanumeric data
2)toolpad command buttons
located on the upper and lower right portions of the GUI
2.Layout Format
二.font
{2}STARTING GAMBIT
一.Startup Command Options
1)gambit -doc 启动本地网页浏览器打开用户手册 >example:gambit -doc
2)gambit -help  显示可用的启动选项           >example:gambit -help
3) gambit -dev (driver)
4) gambit -def (filename)
5) gambit -geom 按像素定义启动窗口大小        >example:gambit -geom 1000 800
6)gambit -id (id)                            >example:gambit
                                                       系统此时会以默认的default_id给文件一个标识
                                               or:     gambit -id jxw
7) gambit -in (filename)
8) gambit -res (filename)
9) gambit -new(默认的启动方式都是新文件)     >example: gambit -id jxw -new=gambit -id jxw
10)gambit -old                                >example: gambit -id gambit_data/3_pipe -old
                                               note: gambit_data目录必须在ntx86
二.GAMBIT File Organization
1)Session Files
.jou
.trn
.dbs
2)Directory Structure
working Directory   存放.jou .trn .dbs文件的临时目录,程序保存退出后删除
Source  Directory   与gambit启动目录是相同的位置,如d:\gambit_v1.3\ntbin\ntx86\
Scratch Directory   与gambit启动目录是相同的位置,如d:\gambit_v1.3\ntbin\ntx86\
home    Directory
{3}GUI
一.GUI Components
二.GUI Control Elements
三.Using the Mouse
1)mouse on "Menus and Forms "  require only left and right buttons
left button:
Open the menu associated with an item on the main menu bar
Select a menu command
Execute the operation indicated on a command button
Select an option from a list of mutually exclusive radio buttons
Open the hidden menu for an option button
Select an option from an option-button menu
Open or close a pick-list form
Enable a text box for entering data
Highlight an item in a list
Relocate (drag) a form on the GUI
right button:
Open a menu of options available by means of a multifunction toolpad command button
Open a hidden menu of options
2)Graphics Window  在图形窗口鼠标可以完成三种任务
  a)产生VERTEX
   Ctrl-right-click
  b)显示图形
    Rotate                    Left-drag,      绕着在屏幕平面上的某个轴旋转,那个轴是于鼠标的移动方向垂直的。
    Translate                 Middle-drag
    Revolve                   Right-drag       水平方向拖动,绕垂直屏幕平面的一中心轴旋转
    Zoom and pan-zoom         Right-drag       垂直方向拖动
    Enlarge                   ctrl+Left-drag   保持比例(即局部放大,导致整体都放大)
                              ctrl+middle-drag 不保持比例(只局部放大)
    Show previous view        Double-middle-click
    Journal view              Double-right-click
    drag                      left+right drag
c)task 执行任务操作
  i)Picking entities
    Shift-left-click  执行单纯的选择操作,在同一个位置有几个实体时,容易选错对象
    Shift-middle-click  执行选择操作,特别适合在一复杂位置处选择一个自己需要的实体(通过不断的Shift-middle-click
                        可以除去前一次的选择,重新选择临近的对象)
ii)Executing actions
  Shift-right-click =apply
四.Using the Global Control Toolpad
{4}GAMBIT MENU COMMANDS
一)file
  1)Export
     i)Mesh Files
      export GAMBIT mesh, boundary-type, and continuum-type information in a format appropriate to the currently
      selected solver
              FDNEUT   FIDAP
              msh      FLUENT/UNS  RAMPANT  FLUENT 5
              GRD      FLUENT 4
              msh      NEKTON
              cdb      ANSYS
              neu      POLYFLOW  Generic
发表于 2002-9-3 15:02:57 | 显示全部楼层
学GAMBIT手记
好东东,欢迎!(···鼓掌中···)
发表于 2002-12-7 14:15:14 | 显示全部楼层
学GAMBIT手记
***** 版主模式 *****
<a href=topic.cgi?forum=15&topic=10>该贴子已被管理员转移,请点击这里查看</a>
发表于 2007-8-15 01:05:41 | 显示全部楼层
学GAMBIT手记
thanks
发表于 2007-8-17 09:07:35 | 显示全部楼层
学GAMBIT手记
thank you!
发表于 2007-8-22 11:18:29 | 显示全部楼层
学GAMBIT手记
太好了,经典啊~~~
