查看: 1481|回复: 1
exceed 安装????
发表于 2003-12-11 22:07:07 | 显示全部楼层 |阅读模式
各位高人所说的fluent安装时,gambit和FLUENT需要把lisence复制到安装目录的lisence目录下。请问gambit和fluent的lisence不是一个吗?在安装文件哪里找到?我的好像没有啊。
  我的系统是winme的,安装不上exceed6.2。提示只能装在windows nt上。是系统问题吗?
  新手。忘高人指点!!
发表于 2003-12-13 11:21:04 | 显示全部楼层
exceed 安装????
Hi boy .
GANBIT and Fluent use the same License file if you set up them in the same directory.So if different directories are found,you need to copy the license file to the correspoding address.
If you have any other problem, maybe I can help you.
Emial:zhong_yun.li@163.com
