查看: 2671|回复: 1
fluent12.1单机多核并行问题
发表于 2017-2-25 23:42:54 | 显示全部楼层 |阅读模式
用ansys12.1中的fluent进行单机多核并行计算该怎么设置,电脑上装过mpich2,该怎么设置啊,打开并行后,导入msh文件出现
unable to read the cmd header on the pmi context, Undefined dynamic error code.
SuspendThread failed with error 5 for process 0:6EF97AFC-F4E9-4b5b-89B1-98F098ED847D:'"G:\ANSYS\ANSYS Inc\v121\fluent\fluent12.1.2\win64\3ddp_node\fl_mpi1212.exe" -mport 10.21.32.153:10.21.32.153:18641:0 node -mpiw mpich2 -pic ethernet'
unable to suspend process.
SuspendThread failed with error 5 for process 2:6EF97AFC-F4E9-4b5b-89B1-98F098ED847D:'"G:\ANSYS\ANSYS Inc\v121\fluent\fluent12.1.2\win64\3ddp_node\fl_mpi1212.exe" -mport 10.21.32.153:10.21.32.153:18641:0 node -mpiw mpich2 -pic ethernet'
999999 (..\src\mpsystem.c@1149): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: Invalid argument
job aborted:
rank: node: exit code[: error message]
0: Lenovo-PC: -1073741819: process 0 exited without calling finalize
1: Lenovo-PC: -1073741819: process 1 exited without calling finalize
2: Lenovo-PC: -1073741819: process 2 exited without calling finalize
发表于 2017-3-1 22:25:40 | 显示全部楼层
Fluent安装时需要先安装MPI,你可以试试重新安装一遍,在安装启动界面上,自上而下依次安装一遍应该就可以了。
