查看: 3730|回复: 3
多块椭圆网格生成软件MegaCads, 免费!
发表于 2003-2-9 20:06:15 | 显示全部楼层 |阅读模式
从http://www.megacads.dlr.de/home.html上ftp来的GUI软件:MegaCads。工作站上用!
MegaCads is part of the MEGAFLOW project and it is used to generate structured multiblock Navier-Stokes grids for high Reynolds-number flows.
MegaCads is an interactive grid generation system (no automation) with a few simple CAD functions, which enables the user to build block boundaries, distribute points on them, create surface grids and fill volume blocks with grids, based on simple representations of shapes through the use of basic objects like polygons and splines in 2D and 3D. The resulting algebraic grids can be smoothed using elliptic or biharmonic techniques. The whole design is done in a parametric fashion and each design step is stored in a script file. Using the built in restart capability, it is possible to change parameters and replay the script file. For further information see the documentation or click here.
如何上传?
发表于 2003-2-11 01:56:07 | 显示全部楼层
I downloaded it and tried it several years ago, it worked well, it works well for both UNIX and LINUX systerm. the only thing is that the user mannual is  German version.
发表于 2003-2-16 21:49:25 | 显示全部楼层
请问,在哪下载?
发表于 2003-2-19 09:22:16 | 显示全部楼层
It used to be let others download , but I am not sure about that now.
