查看: 1991|回复: 3
[求助]这个问题怎么办呀?大伙来看看!
发表于 2004-5-20 16:45:32 | 显示全部楼层 |阅读模式
马赫数为5
大气环境为:压力1.0524627pa   密度:1.84583*10-5  kg/m3
            粘度:1.3208*10-5 kg/(s.m)     温度:198.639k
我设定条件后就是不能运算,我设得条件为:coupled implicit,2d,S-A viscous model,Energy equation,desity用ideal-gas,Cp用constant 1006.43, Thermal conductivity 用constant 0.0242, viscosity 用sutherland, operating pressure用0pa,
pressure_far_feild 边界条件!
每次运算都不能进行!!!出现如下错误:
  iter continuity x-velocity y-velocity     energy        nut     time/iter
divergence detected - temporarily reducing Courant number to 0.5
and trying again...
divergence detected - temporarily reducing Courant number to 0.05
and trying again...
divergence detected - temporarily reducing Courant number to 0.005
and trying again...
divergence detected - temporarily reducing Courant number to 0.0005
and trying again...
divergence detected - temporarily reducing Courant number to 5e-05
and trying again...
Error: Internal error at line 806 in file 'rp_mstage.c'.
divergence detected in AMG solver
Error Object: ()
谢谢指点!
发表于 2004-5-20 17:13:58 | 显示全部楼层
[求助]这个问题怎么办呀?大伙来看看!
已经很明显了,让你降低Courant数啊。
 楼主| 发表于 2004-5-21 10:53:00 | 显示全部楼层
[求助]这个问题怎么办呀?大伙来看看!
我降低courant数到0.005还是不行呀!
发表于 2004-5-21 22:27:06 | 显示全部楼层
[求助]这个问题怎么办呀?大伙来看看!
降到0。0000000005试试。
