查看: 988|回复: 5
[求助]
发表于 2004-8-13 23:22:46 | 显示全部楼层 |阅读模式
Hi everyone
I need a license for FLUENT POLYFLOW v.3.10.0
Very urgently!
Email: carljian@tpg.com.au
Thanks a lot!
发表于 2004-8-14 14:28:20 | 显示全部楼层
[求助]
give you !good luck!
发表于 2004-8-14 14:28:57 | 显示全部楼层
[求助]
Good luck
 楼主| 发表于 2004-8-14 19:52:06 | 显示全部楼层
[求助]
Dear 沙海飞
Many thanks for your offering with your kind and wonderful mind and spirit while I was blocked on the way of forwarding.In fact we used to be a neighbor.I came from Shanghai, now I am living in Brisbane Queensland Australia.OK, keep in touch with my personal email address.
I've already tested the license supplied by you. Singly running is fine.
But problem is that POLYFlOW consists of many packages with diffferent licenses.The license for GAMBIT was ever located at its default path (i.e.....\license) by me, however I cannot put the license for POLYFLOW with the same name (license) into the same location, otherwise other license data will be overwritten. Therefore I installed LMTOOLS  so that licenses can be managed by it. However some problems still existed.
If possible, please tell me about how to solve such problem with your method.
Thanks again
Carl Jiang
 楼主| 发表于 2004-8-15 15:25:29 | 显示全部楼层
[求助]
Hi 沙海飞
  O my God! I've already solved above problem, and tested my new 2in1 license successfully.So I want to share with others who need to run GAMBIT v2.1.6 and POLYFLOW v.3.10.0.and also give them a hint to make your own license. The method of installation please refer to inside note. Very simple and easily! Have fun!
Carl Jiang
p.s Thanks for 沙海飞's second license offering!
 楼主| 发表于 2004-8-15 15:47:44 | 显示全部楼层
[求助]
File failed to lodge here to see "SHARE" item.
