查看: 2315|回复: 2
关于网格划分,在线求!
发表于 2004-12-5 22:03:14 | 显示全部楼层 |阅读模式
划分三维网格时,在结构网格和非结构网格分解处出错,信息如下:
Initialization failed;perturb boundary nodes and try again.
Initialization failed to mesh 2 nodes.
ERROR:TG_Mesh_Domain failed with error code 1.
ERROR:Tetrahedral meshing has failed for volume volum 14.
This is usually caused by problem in the face meshes.
Check the skewnesses of your face meshes and make surethe face mesh sizes are not too large in areas of small gaps.[USECHGFONTE]
发表于 2013-5-21 12:59:16 | 显示全部楼层
回复 1# 哎呀 的帖子
楼主问题解决了么,碰到同样的问题,求教!
发表于 2013-5-21 13:59:18 | 显示全部楼层
可以上传个模型看看
