查看: 2601|回复: 0
UDF计算
发表于 2018-4-4 16:31:10 | 显示全部楼层 |阅读模式
10金钱
请教一下大家,就是想输入一个x轴上的加速度随时间变化的曲线,用书上的程序计算不了,用我的程序能计算但结果不对,请问一下是为啥
/* UDF for specifying an x-momentum source term in a spatially     */
/* dependent porous media                                          */
#include "udf.h"
#define C2 100.0
DEFINE_SOURCE(xmom_source, c, t, dS, eqn)
  real x[ND_ND];
  real con, source;
  C_CENTROID(x, c, t);
  con = C2*0.5*C_R(c, t)*x[1];
  source = -con*fabs(C_U(c, t))*C_U(c, t);
  dS[eqn] = -2.*con*fabs(C_U(c, t));
  return source;
计算时就会出现这种情况
Node 0: Process 8516: Received signal SIGSEGV.
Node 1: Process 8972: Received signal SIGSEGV.
Node 2: Process 8036: Received signal SIGSEGV.
Node 4: Process 1380: Received signal SIGSEGV.
Node 5: Process 7764: Received signal SIGSEGV.
Node 6: Process 9360: Received signal SIGSEGV.
Node 3: Process 7944: Received signal SIGSEGV.
MPI Application rank 0 exited before MPI_Finalize() with status 2
The fl process could not be started.
这是我自己的代码,能计算但感觉没起到什么效果
The acceleration in the x-axis direction changes with time
#include "udf.h"
#define g 9.8
DEFINE_SOURCE(accelaration_source, c, t, dS, eqn)
  real x[ND_ND];
  real source;
  real a = RP_Get_Real ("CURRENT_TIME" );
  source = -0.125*CURRENT_TIME*g+0.5*g;
  source=x[0];
  dS[eqn] = 0.0;
  return source;
