查看: 927|回复: 0
[原创]fluent6.2 new feature
发表于 2005-3-11 14:47:06 | 显示全部楼层 |阅读模式
[watermark]FLUENT 6.2 contains new capabilities in several areas. All multiphase models can be used in conjunction with species transport and chemical reactions. Free surface and discrete phase modeling are both significantly more efficient and a new solar radiation model opens up whole new application areas. FLUENT’s unique dynamic mesh capability for simulating flows around moving bodies has been enhanced including the addition of a new six-degrees-of-freedom solver. FLUENT 6.2 also offers the most comprehensive range of turbulence and acoustics models in any CFD code. FLUENT’s already considerable capacity for handling chemically reacting flows has been expanded with a new, efficient laminar stiff chemistry solver, special models for engine ignition, and a convenient facility to create custom, reusable, material property databases.
[/watermark]
