查看: 7673|回复: 3
Velocity transformation for compressible wall-bounded turbulent flows with an...
发表于 2021-8-21 00:19:50 | 显示全部楼层 |阅读模式
In this community, we have the well-known log law for incompressible wall-bounded turbulence. Over the past decades, people are wondering:
(1) Does the log law exist for the high-speed wall-bounded turbulence?
(2) If yes, what is the exact formulation?
With the Ph.D. student Kevin Griffin and Prof. Parviz Moin, we give our answer on our PANS paper:
https://www.researchgate.net/publication/354010175_Velocity_transformation_for_compressible_wall-bounded_turbulent_flows_with_and_without_heat_transfer/stats
https://www.pnas.org/content/118/34/e2111144118
发表于 2021-8-23 12:13:02 | 显示全部楼层
直接把pdf文档贴上来多好
 楼主| 发表于 2021-8-23 19:56:38 | 显示全部楼层
@周华 见附件
PNAS_Lin.pdf
2.22 MB, 下载次数: 6
 楼主| 发表于 2021-8-23 19:57:55 | 显示全部楼层
关于这篇文章的 邀请报告
