查看: 2237|回复: 0
请问CFD_Screening计算报错怎么解决
发表于 2022-10-27 18:47:54 | 显示全部楼层 |阅读模式
DESIGN3D STOPPED DUE TO THE FOLLOWING ERROR
  The flow computation blew up.
The post-processing task has been skipped.
Computation info:
                Design3D - version 17.1
                           compiled for MS Windows x86-64
                           on Feb 25 2022
                NUMECA International S.A.
INFO - PVM daemon is running for user 'ZHOUTAO'
PVM Initialized
STARTUP_ERROR: Could not find HOME in environment variables:
STARTUP_ERROR: Could not find HOMEDRIVE in environment variables:
STARTUP_ERROR: Could not find HOMEPATH in environment variables:
Info    : Using USERPROFILE Env.Var.: C:\Users
Info    : AppData is C:\Users\AppData\Roaming
Using Parasolid V32.1.222
Reading outputs database from resource file: E:\NUMECA_SOFTWARE\Fine171\bin\euranus_outputs.def
                        SCREENING
PARAMETRIC MODELER /////////////////////////////////////////////////
STEP 1 : Update model ........................................... OK
CFD MESH GENERATOR /////////////////////////////////////////////////
STEP 1 : Locate .trb file ....................................... OK
STEP 2 : Rebuild geometry .................................. SKIPPED
  Run AutoGrid
pvm_spawn task = 'iggx86_64.exe'
argv:
    '-niversion'
    '171'
    '-print'
    '-real-batch'
    '-autogrid5'
    '-trb'
    'G:\case\16e\16emodel\WP16e\rotor\rotor\rotor_SCN\_trk\_flow\_mesh\rotor.trb'
    '-geomTurbo'
    'G:\case\16e\16emodel\WP16e\rotor\rotor\rotor_SCN\_trk\_flow\_mesh\rotor.geomTurbo'
    '-mesh'
    'G:\case\16e\16emodel\WP16e\rotor\rotor\rotor_SCN\_trk\_flow\_mesh\rotor.igg'
    '-job_design3d'
    'G:\case\16e\16emodel\WP16e\rotor\rotor\rotor_SCN\_trk\_flow\_mesh\job_igg_autogrid'
    '-jd3d'
    '0EC2FE94815C65F72302CE0F265453D2'
    '-parendId'
    '262157'
hostname = 'DESKTOP-3CKG8LS'
-> +1, tid = +262158
        job #0 - AutoGrid - started on config #0
        job #0 - AutoGrid - finished
STEP 3 : Generate mesh .......................................... OK
local_quality_report_file = G:\case\16e\16emodel\WP16e\rotor\rotor\rotor_SCN\_trk\_flow\_mesh\rotor.qualityReport
STEP 4 : Check mesh quality ..................................... OK
STEP 5 : Merge mesh (multistage) ........................... SKIPPED
CFD SOLVER /////////////////////////////////////////////////////////
Run Euranus
NIBCDataBase::clear lists
NIBCDataBase::read:
STEP 1 : Save .run file ......................................... OK
STEP 2 : Compute wall distances ............................ SKIPPED
memoryEstimation(), pid_min +0, pid_max: +0
pvm_spawn task = 'euranusx86_64.exe'
argv:
    'G:\case\16e\16emodel\WP16e\rotor\rotor\rotor_SCN\_trk\_flow\computation_1\computation_1.run'
    '-steering'
    'G:\case\16e\16emodel\WP16e\rotor\rotor\rotor_SCN\_trk\_flow\computation_1\computation_1.steering'
    '-niversion'
    '171'
    '-f3d_report'
    '-print'
    '-job_design3d'
    'G:\case\16e\16emodel\WP16e\rotor\rotor\rotor_SCN\_trk\_flow\computation_1\job_euranus'
    '-jd3d'
    '1BD2FFF977EF819808A586E9CEA4D07B'
    '-parendId'
    '262157'
    '-pgi'
    '-seq'
-> +1, tid = +262159
        job #0 - Euranus - started on config #0
        job #0 - Euranus - finished as 'crashed'
STEP 3 : Perform CFD simulation ................................. OK
Computation_Name_Vector(0)   = 'computation_1'
Computation_Active_Vector(0) = 1
The flow computation blew up!
STEP 4 : Check CFD solution ........... FAILED (COMPUTATION BLEW UP)
[error - 18:43:10]        The flow computation blew up.
cpu time....... +110.616666666666660 sec.
system time.... +1.000000000000000 sec.
user time...... +111.000000000000000 sec.
[info - 18:43:10]        Processor #0 is stopped
[info - 18:43:13]             Design3D execution has ended.
