查看: 2593|回复: 0
向大佬们请求报错原因
发表于 2023-5-29 09:57:57 | 显示全部楼层 |阅读模式
截图好像不好使,直接复制粘贴了,能读懂,但是不知道具体原因。A java.lang.RuntimeException exception has occurred.However, the system should continue working without further problems.Click Show Details for the stack trace.“发生java.lang.RuntimeException异常。不过,系统应该会继续工作,不会出现更多问题。”
这个错误是我在清除一次求解之后显示的,也不清楚,打开detail如下列,好想是数据缺失???
java.lang.RuntimeException: Data does not exists in ColumnNode<T>::getDataon expression: row < (size_t)numTuplesin file: ColumnNode_t.hon line: 159SymInit: Symbol-SearchPath: '', symOptions: 1556, UserName: 'admin'OS-Version: 6.2.9200 () 0x100-0x100007FFF7F86C021 (StarPlatform): (filename not available): (function-name not available)00007FFF7F8854FA (StarPlatform): (filename not available): (function-name not available)00007FFF86453478 (StarNeo): (filename not available): (function-name not available)00007FFF8644C68A (StarNeo): (filename not available): (function-name not available)00007FFF7A52FEFB (StarSceneGraphRenderer): (filename not available): (function-name not available)00007FFF7A530A17 (StarSceneGraphRenderer): (filename not available): (function-name not available)00007FFF7A53038F (StarSceneGraphRenderer): (filename not available): (function-name not available)00007FFF7A2EB10B (StarSceneGraphRenderer): (filename not available): (function-name not available)00007FFF7A2E9C0E (StarSceneGraphRenderer): (filename not available): (function-name not available)00007FFF7A2E922E (StarSceneGraphRenderer): (filename not available): (function-name not available)00007FFF7A103D2C (StarSceneGraphWidget): (filename not available): (function-name not available)00007FFF7A136EC2 (StarSceneGraphWidget): (filename not available): (function-name not available)00007FFF7A136D7D (StarSceneGraphWidget): (filename not available): (function-name not available)00007FFF7AAFD9ED (StarSceneGraphLocalRenderer): (filename not available): (function-name not available)00007FFF8697E87D (StarSceneGraphJava): (filename not available): (function-name not available)000002422B11072F ((module-name not available)): (filename not available): (function-name not available)0000024245A5DB40 ((module-name not available)): (filename not available): (function-name not available)000000074C1970B0 ((module-name not available)): (filename not available): (function-name not available)0000000704A5B950 ((module-name not available)): (filename not available): (function-name not available)000002422ABE671C ((module-name not available)): (filename not available): (function-name not available)0000000000000007 ((module-name not available)): (filename not available): (function-name not available)        at star.vis.scenegraph.Interactor.InputEvent(Native Method)        at star.vis.scenegraph.Interactor.lambda$inputEvent$2(Interactor.java:209)        at star.vis.scenegraph.SsgProcessor$Processor.run(SsgProcessor.java:87)[catch] at java.base/java.lang.Thread.run(Thread.java:834)
