查看: 23|回复: 0
求助,计算报错
发表于 昨天 18:04 | 显示全部楼层 |阅读模式
最近在做一个流固耦合计算,遇到了报错卡了很久,求各位帮助,模型入口流速在一个区间内可以计算成功,大于或小于这个区间都会报错,也搜索了一些办法,都无济于事,不管怎么调整,最后都会出现下面两种报错的其中一种,求解答
(1)
| ERROR #001100279 has occurred in subroutine ErrAction.             |
| CFX encountered the error: Read.  Fatal error occurred when reque- |
| sting Total Mesh Displacement for fs.                              |
| cplg_SendCommand failed to send the command: ERROR -- CFX encount- |
| ered the error: Read.  Fatal error occurred when requesting Total  |
| Stopped in routine cplg_SendCommand                                |
|                An error has occurred in cfx5solve:                 |
| The ANSYS CFX solver exited with return code 1.   No results file  |
| has been created.                                                  |
(2)
| ERROR #002100061 has occurred in subroutine SERVE_CLIENTS.         |
| The connection between this CFX process and an external process    |
| has died unexpectedly.  The following error was received:          |
|   External process  : ANSYS                                        |
|   Error experienced : Read                                         |
| ** This error is fatal:  Terminating ANSYS CFX Solver execution ** |
| Please review the output, error and log files from both the CFX    |
| and external processes to determine the cause of the error.        |
| has been created.                                                  |
