查看: 1574|回复: 3
a problem about dynamic mesh
发表于 2005-5-16 14:12:10 | 显示全部楼层 |阅读模式
Hi
I';m having trouble getting the UDF DEFINE_GEOM to work properly. I would like to use the UDF to make the bottom of a rectangular duct with air blowing deform into a different shape over time. I have compiled the UDF properly and have hooked it into fluent as outlined in the UDF user';s manual. However, when I view the mesh motion, the bottom does not deform.
I would really appreciate your help. My e-mail is sxy_hit@163.com
My project is shown as follow.  I will give you some file about my problem. Thank you!
The bottom of the duct is from (-5,-2.5) to (-5,2.5). the new position is defined by a parabola through (-5,-2.5), (0,-1) and (-5,2.5). The parabola is  .
*   defining parabola through points (-5,-2.5),(0,-1),(5,-2.5)
#include "udf.h"
DEFINE_GEOM(parabola,domain,dt,position)
/*set y=-0.06x^2-1*/
position[1]=-0.06*position[0]*position[0]-1;
 楼主| 发表于 2005-5-16 14:12:59 | 显示全部楼层
DEFINE_GEOM
 楼主| 发表于 2005-5-16 14:18:44 | 显示全部楼层
相关文件
发表于 2005-5-29 10:35:39 | 显示全部楼层
guanzhu
