查看: 2505|回复: 4
[求助]并行计算
发表于 2005-5-29 10:59:28 | 显示全部楼层 |阅读模式
双CPU,2G内存。Fluent6.2。计算气体和液滴的两相流场。液滴采用DPM模型。
计算出现以下错误:
iter continuity x-velocity y-velocity z-velocity     energy          k    epsilon        h2o         o2     time/iter
cells....,
reversed flow in 448 faces on pressure-outlet 8.
     1 1.0000e+00 1.4117e-04 7.1466e-05 4.9898e-05 1.2743e-05 1.4196e-02 1.0247e-01 0.0000e+00 0.0000e+00  0:21:27   99
     2 1.0000e+00 7.5064e-01 7.1660e-02 1.0175e-01 2.2792e-05 2.9567e+00 6.8308e+01 0.0000e+00 0.0000e+00  0:21:14   98
     3 2.3066e-01 2.2425e-01 1.2796e-01 1.3982e-01 1.1619e-05 1.9086e-01 4.9861e-01 0.0000e+00 0.0000e+00  0:20:42   97
     4 2.5593e-01 1.8796e-01 1.6913e-01 1.8862e-01 7.0765e-06 7.9293e-02 1.4126e-01 0.0000e+00 0.0000e+00  0:20:13   96
     5 1.5851e-01 1.1413e-01 5.4141e-02 6.3537e-02 5.4652e-06 6.9536e-02 1.2505e-01 0.0000e+00 0.0000e+00  0:19:49   95
     6 1.0353e-01 6.7323e-02 3.4183e-02 4.8095e-02 1.9630e-06 7.2258e-02 1.1800e-01 0.0000e+00 0.0000e+00  0:19:27   94
     7 7.6537e-02 4.5360e-02 3.5901e-02 4.1839e-02 9.5555e-07 6.9779e-02 1.1406e-01 0.0000e+00 0.0000e+00  0:19:06   93
     8 5.5634e-02 2.2349e-02 1.3944e-02 2.0230e-02 7.0568e-07 7.1367e-02 1.1313e-01 0.0000e+00 0.0000e+00  0:18:48   92
     9 4.5636e-02 1.7687e-02 8.2685e-03 1.4317e-02 2.5635e-07 6.9619e-02 1.0896e-01 0.0000e+00 0.0000e+00  0:18:49   91
DPM Iteration ....
999999 (..\..\src\mpsystem.c@1228): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory
Process [0] exited with status [-1073741819]
Process [1] exited with status [-1]
Process [2] exited with status [-1]
Process [3] exited with status [-1]
MPIRUN exited with status [0]
The Parallel FLUENT process could not be started.
请教有谁知道吗?先谢了!
 楼主| 发表于 2005-5-29 11:27:55 | 显示全部楼层
[求助]并行计算
操作系统windowsxp!
发表于 2009-3-6 20:06:45 | 显示全部楼层
请问楼主,您的问题解决了吧?我也遇到了您同样的问题,请问您是怎么解决了的呢?
发表于 2009-3-24 10:23:00 | 显示全部楼层
我也是碰到同样的问题 请问楼上解决了么
发表于 2011-11-17 14:53:16 | 显示全部楼层
页面载入出错
