查看: 1692|回复: 1
各位大侠帮忙
发表于 2004-4-11 09:14:32 | 显示全部楼层 |阅读模式
以下是我的Q1文件,我调了n次了,还是不收敛:(,欲哭无泪呀
请各位高手指定一,二
Group 1. Run Title
TEXT(                                        )
  Group 2. Transience
STEADY  =    T
  Groups 3, 4, 5  Grid Information
    * Overall number of cells, RSET(M,NX,NY,NZ,tolerance)
RSET(M,23,20,54)
  Group 6. Body-Fitted coordinates
  Group 7. Variables: STOREd,SOLVEd,NAMEd
ONEPHS  =    T
    * Non-default variable names
NAME( 16) =SMOK ; NAME( 43) =EPOR
NAME( 46) =BLOK ; NAME( 47) =PRPS
NAME( 49) =DEN1 ; NAME( 50) =TEM1
NAME(150) =SPH1
    * Solved variables list
SOLVE(P1  ,U1  ,V1  ,W1  ,SMOK,TEM1)
    * Stored variables list
STORE(SPH1,DEN1,PRPS,BLOK,EPOR)
    * Additional solver options
SOLUTN(P1  ,Y,Y,Y,N,N,N)
SOLUTN(TEM1,Y,Y,Y,N,N,Y)
IVARBK  =        -1 ;ISOLBK =         1
TURMOD(KEMODL)
  Group 8. Terms & Devices
ISOLX   =         0 ;ISOLY  =         0 ;ISOLZ  =         0
DENPCO  =    T
  Group 9. Properties
PRESS0  = 1.000000E+05 ;TEMP0  = 2.730000E+02
SETPRPS(1,  0)
DVO1DT  = 3.410000E-03
PRNDTL(TEM1) = -2.580000E-02
PRT   (EP  ) =  1.314000E+00
  Group 10.Inter-Phase Transfer Processes
  Group 11.Initialise Var/Porosity Fields
FIINIT(KE  ) =  1.001000E-10 ;FIINIT(EP  ) =  1.001000E-10
FIINIT(EPOR) =  1.000000E+00 ;FIINIT(BLOK) =  1.000000E+00
FIINIT(PRPS) = -1.000000E+00 ;FIINIT(DEN1) =  1.001000E-10
FIINIT(TEM1) =  1.900000E+01
   No PATCHes used for this Group
INIADD  =    F
  Group 12. Convection and diffusion adjustments
  Group 13. Boundary & Special Sources
PATCH (BUOYANCY,PHASEM,0,0,0,0,0,0,1,1)
COVAL (BUOYANCY,U1  , FIXFLU      , GRND3       )
COVAL (BUOYANCY,V1  , FIXFLU      , GRND3       )
COVAL (BUOYANCY,W1  , FIXFLU      , GRND3       )
BUOYA   = 0.000000E+00 ; BUOYB =-9.810000E+00
BUOYC   = 0.000000E+00
BUOYE   = 2.000000E+01
EGWF    =    T
  Group 14. Downstream Pressure For PARAB
  Group 15. Terminate Sweeps
LSWEEP  =      1000
RESFAC  = 1.000000E-02
  Group 16. Terminate Iterations
LITER (TEM1) =       15
ENDIT (TEM1) =  GRND1
  Group 17. Relaxation
RELAX(P1  ,LINRLX, 1.000000E+00)
RELAX(U1  ,FALSDT, 1.000000E-02)
RELAX(V1  ,FALSDT, 1.000000E-02)
RELAX(W1  ,FALSDT, 1.000000E-02)
RELAX(KE  ,LINRLX, 3.000000E-01)
RELAX(EP  ,LINRLX, 3.000000E-01)
RELAX(SMOK,FALSDT, 1.000000E+01)
RELAX(TEM1,FALSDT, 5.000000E+01)
KELIN   =         0
  Group 18. Limits
VARMAX(U1  ) = 1.000000E+06 ;VARMIN(U1  ) =-1.000000E+06
VARMAX(V1  ) = 1.000000E+06 ;VARMIN(V1  ) =-1.000000E+06
VARMAX(W1  ) = 1.000000E+06 ;VARMIN(W1  ) =-1.000000E+06
  Group 19. EARTH Calls To GROUND Station
USEGRD  =    T  ;USEGRX =    T
NAMGRD  =FLAR
GENK    =    T
ASAP    =    T
IDISPB  =         1 ;IDISPC =        30
  Group 20. Preliminary Printout
ECHO    =    T
  Group 21. Print-out of Variables
  Group 22. Monitor Print-Out
IXMON   =        10 ;IYMON  =         5 ;IZMON  =        42
NPRMON  =    100000
NPRMNT  =         1
TSTSWP  =        -1
  Group 23.Field Print-Out & Plot Control
NPRINT  =    100000
NXPRIN  =         7
NYPRIN  =         6
NPLT    =         1
ISWPRF  =         1 ;ISWPRL =    100000
  Group 24. Dumps For Restarts
IDISPA  =         1 ;IDISPB =         1 ;IDISPC =        30
CSG1    ='trai'
GVIEW(P,-1.925887E-02,-2.068010E-01,9.781936E-01)
GVIEW(UP,-7.350019E-02,9.760206E-01,2.048945E-01)
> DOM,    SIZE,        1.800000E+00, 1.800000E+00, 6.000000E+00
> DOM,    MONIT,       8.250000E-01, 2.430250E-01, 4.493750E+00
> DOM,    SCALE,       1.000000E+00, 1.000000E+00, 1.000000E+00
> DOM,    SNAPSIZE,    1.000000E-02
> GRID,   RSET_X_1,      5, 1.000000E+00
> GRID,   RSET_X_3,      2, 1.000000E+00
> GRID,   RSET_X_8,      1, 1.000000E+00
> GRID,   RSET_X_9,      1, 1.000000E+00
> GRID,   RSET_X_10,      2, 1.000000E+00
> GRID,   RSET_X_11,      1, 1.000000E+00
> GRID,   RSET_X_12,      1, 1.000000E+00
> GRID,   RSET_X_13,      5, 1.000000E+00
> GRID,   RSET_Y_1,      2, 1.000000E+00
> GRID,   RSET_Y_2,      1, 1.000000E+00
> GRID,   RSET_Y_3,      2, 1.000000E+00
> GRID,   RSET_Y_4,      2, 1.000000E+00
> GRID,   RSET_Y_5,      1, 1.000000E+00
> GRID,   RSET_Y_6,      1, 1.000000E+00
> GRID,   RSET_Y_7,     11, 1.000000E+00
> GRID,   RSET_Z_1,      4, 1.000000E+00
> GRID,   RSET_Z_2,      4, 1.000000E+00
> GRID,   RSET_Z_3,      4, 1.000000E+00
> GRID,   RSET_Z_4,      4, 1.000000E+00
> GRID,   RSET_Z_5,      4, 1.000000E+00
> GRID,   RSET_Z_6,      1, 1.000000E+00
> GRID,   RSET_Z_7,      3, 1.000000E+00
> GRID,   RSET_Z_8,      1, 1.000000E+00
> GRID,   RSET_Z_9,      4, 1.000000E+00
> GRID,   RSET_Z_10,      2, 1.000000E+00
> GRID,   RSET_Z_11,      1, 1.000000E+00
> GRID,   RSET_Z_12,      2, 1.000000E+00
> GRID,   RSET_Z_13,      4, 1.000000E+00
> GRID,   RSET_Z_14,      4, 1.000000E+00
> GRID,   RSET_Z_15,      2, 1.000000E+00
> GRID,   RSET_Z_16,      1, 1.000000E+00
> GRID,   RSET_Z_17,      1, 1.000000E+00
> GRID,   RSET_Z_18,      8, 1.000000E+00
> OBJ,    NAME,        R-CARR1
> OBJ,    POSITION,    5.780000E-01, 0.000000E+00, 5.000000E-01
> OBJ,    SIZE,        0.000000E+00, 7.200000E-01, 1.880000E+00
> OBJ,    CLIPART,     cube11
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         24
> OBJ,    POROSITY,      0.000000E+00
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        LCARR1
> OBJ,    POSITION,    1.216000E+00, 0.000000E+00, 5.000000E-01
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         24
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        B-CARRIA
> OBJ,    SIZE,        6.400000E-01, 0.000000E+00, 4.500000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         24
> OBJ,    NAME,        TCARR1
> OBJ,    POSITION,    5.780000E-01, 7.200000E-01, 5.000000E-01
> OBJ,    SIZE,        6.400000E-01, 0.000000E+00, 2.870000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         24
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        DOOR1-R
> OBJ,    POSITION,    5.800000E-01, 0.000000E+00, 5.000000E-01
> OBJ,    SIZE,        2.000000E-01, 7.200000E-01, 0.000000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         42
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        C-2
> OBJ,    POSITION,    5.800000E-01, 0.000000E+00, 9.500000E-01
> OBJ,    SIZE,        4.000000E-01, 7.200000E-01, 0.000000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        DOOR2-L
> OBJ,    POSITION,    5.800000E-01, 0.000000E+00, 5.000000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         42
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        OPENING1
> OBJ,    POSITION,    0.000000E+00, 0.000000E+00, 6.000000E+00
> OBJ,    SIZE,        1.800000E+00, 1.800000E+00, 0.000000E+00
> OBJ,    CLIPART,     cube12t
> OBJ,    ROTATION24,        1
> OBJ,    VISIBLE,          -1
> OBJ,    TYPE,        OPENING
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,        214
> OBJ,    PRESSURE,      0.000000E+00
> OBJ,    TEMPERATURE,   1.700000E+01
> OBJ,    COEFFICIENT,   1.000000E+00
> OBJ,    VELOCITY,      0.000000E+00, 0.000000E+00,-6.000000E-01
> OBJ,    TURBULENCE,    SAME        , SAME
> OBJ,    NAME,        FIRE
> OBJ,    POSITION,    8.000000E-01, 2.100000E-03, 4.750000E+00
> OBJ,    SIZE,        1.200000E-01, 7.000000E-02, 1.200000E-01
> OBJ,    CLIPART,     cylinder
> OBJ,    ROTATION24,        5
> OBJ,    TYPE,        FIRE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         15
> OBJ,    STARTING,      0.000000E+00
> OBJ,    DURATION,      9.000000E+02
> OBJ,    PRE-TEMP,      1.700000E+01
> OBJ,    MASS-SOURCE,     Fixed Rate
> OBJ,    FXD-MASS,      1.400000E-04
> OBJ,    HEAT-SOURCE,     Pool Fire
> OBJ,    EFFICIENCY,      5.000000E-01
> OBJ,    HEAT-COMB,      4.200000E+07
> OBJ,    SCALAR-SOURCE,   Fixed value
> OBJ,    INLET_SMOK,    1.000000E+00
> OBJ,    NAME,        DOOR1-L
> OBJ,    POSITION,    1.020000E+00, 0.000000E+00, 5.000000E-01
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         42
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        DOOR2-R
> OBJ,    POSITION,    1.020000E+00, 0.000000E+00, 5.000000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         42
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        BT
> OBJ,    POSITION,    7.800000E-01, 6.200000E-01, 5.000000E-01
> OBJ,    SIZE,        2.400000E-01, 1.000000E-01, 0.000000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         42
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        TT
> OBJ,    POSITION,    7.800000E-01, 6.200000E-01, 5.000000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         42
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        TOPWIN
> OBJ,    POSITION,    8.500000E-01, 7.200000E-01, 3.370000E+00
> OBJ,    SIZE,        1.000000E-01, 0.000000E+00, 1.000000E-01
> OBJ,    CLIPART,     cube3t
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        INLET
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,        214
> OBJ,    VELOCITY,      0.000000E+00, 0.000000E+00, 0.000000E+00
> OBJ,    TEMPERATURE,   1.800000E+01
> OBJ,    TURB-INTENS,   5.000000E+00
> OBJ,    NAME,        RWIN2
> OBJ,    POSITION,    5.780000E-01, 3.000000E-01, 2.380000E+00
> OBJ,    SIZE,        0.000000E+00, 2.000000E-01, 3.000000E-01
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        OPENING
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,        214
> OBJ,    OPAQUE,           100
> OBJ,    TEMPERATURE,   SAME
> OBJ,    NAME,        C-3
> OBJ,    POSITION,    5.800000E-01, 0.000000E+00, 1.400000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        C-4
> OBJ,    POSITION,    5.800000E-01, 0.000000E+00, 1.850000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        C-5
> OBJ,    POSITION,    5.800000E-01, 0.000000E+00, 2.300000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        C-6
> OBJ,    POSITION,    5.800000E-01, 0.000000E+00, 2.750000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        C-7
> OBJ,    POSITION,    5.800000E-01, 0.000000E+00, 3.200000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        C-8
> OBJ,    POSITION,    5.800000E-01, 0.000000E+00, 3.650000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        C-9
> OBJ,    POSITION,    5.800000E-01, 0.000000E+00, 4.100000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        C-10
> OBJ,    POSITION,    5.800000E-01, 0.000000E+00, 4.550000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        LWIN2
> OBJ,    POSITION,    1.216000E+00, 3.000000E-01, 2.380000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        OPENING
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,        214
> OBJ,    NAME,        BDOOR
> OBJ,    POSITION,    7.800000E-01, 0.000000E+00, 5.000000E-01
> OBJ,    SIZE,        2.400000E-01, 6.200000E-01, 0.000000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        OPENING
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         15
> OBJ,    NAME,        OPENING2
> OBJ,    POSITION,    0.000000E+00, 0.000000E+00, 0.000000E+00
> OBJ,    ROTATION24,        1
> OBJ,    VISIBLE,          -1
> OBJ,    TYPE,        OPENING
> OBJ,    NAME,        R-CARR2
> OBJ,    POSITION,    5.780000E-01, 0.000000E+00, 2.680000E+00
> OBJ,    SIZE,        0.000000E+00, 7.200000E-01, 2.320000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         24
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        LCARR2
> OBJ,    POSITION,    1.216000E+00, 0.000000E+00, 2.680000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         24
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        R2B
> OBJ,    POSITION,    5.780000E-01, 0.000000E+00, 2.380000E+00
> OBJ,    SIZE,        0.000000E+00, 3.000000E-01, 3.000000E-01
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         24
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        R2T
> OBJ,    POSITION,    5.780000E-01, 5.000000E-01, 2.380000E+00
> OBJ,    SIZE,        0.000000E+00, 2.200000E-01, 3.000000E-01
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         24
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        L2B
> OBJ,    POSITION,    1.216000E+00, 0.000000E+00, 2.380000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         24
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        L2T
> OBJ,    POSITION,    1.216000E+00, 5.000000E-01, 2.380000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         24
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        TCARR2
> OBJ,    POSITION,    5.800000E-01, 7.200000E-01, 3.470000E+00
> OBJ,    SIZE,        6.400000E-01, 0.000000E+00, 1.530000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         24
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        TWIN1
> OBJ,    POSITION,    5.800000E-01, 7.200000E-01, 3.370000E+00
> OBJ,    SIZE,        2.700000E-01, 0.000000E+00, 1.000000E-01
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         24
> OBJ,    SIDE,        BOTH
> OBJ,    NAME,        TWIN2
> OBJ,    POSITION,    9.500000E-01, 7.200000E-01, 3.370000E+00
> OBJ,    ROTATION24,        1
> OBJ,    TYPE,        PLATE
> OBJ,    COLOR-MODE,         2
> OBJ,    COLOR-VAL,         24
> OBJ,    OPAQUE,            50
> OBJ,    SIDE,        BOTH
STOP
 楼主| 发表于 2004-4-16 10:08:25 | 显示全部楼层
各位大侠帮忙
怎么没有人给我指点一二?
