查看: 4448|回复: 10
我想查看某一点具体的计算值,来和实验值进行比较,RESULT里有吗?
发表于 2002-8-15 12:25:07 | 显示全部楼层 |阅读模式
RESULT里有很多值,不知是哪一个?
这下面就是我模拟的计算结果,很多东东不懂?
这里面好多变量不懂,请问一般只看哪几种变量?
TIME STP=     1 SWEEP NO=   200 ZSLAB NO=    10 ITERN NO=     1
(这上面几个东东是啥意思)???
         CCCC HHH        PHOENICS Version 3.2.0 - EARTH
      CCCCCCCC     H     (C) Copyright 1999
    CCCCCCC    See   H   Concentration Heat and Momentum Ltd
   CCCCCCC   our new  H  All rights reserved.
   CCCCCC    Web-site  H  Address:  Bakery House, 40 High St
   CCCCCCC  www.cham. H  Wimbledon, London, SW19 5AU
    CCCCCCC   co.uk  H   Tel:       0181-947-7651
      CCCCCCCC     H     Facsimile: 0181-879-3497
         CCCC HHH        E-mail:  phoenics@cham.co.uk
  This program forms part of the PHOENICS installation for:
                   CHAM
  The code expiry date is the end of : Jun 1999
Number of F-array locations available is              21000000
Number used before BFC allowance is                     281512
Number used after BFC allowance is                      281512
(这上面三个东东是啥意思)???
  Group 1. Run Title and Number
TEXT(cai the first simulation                )
IRUNN   =       1 ;LIBREF =     302
(这上面东东是啥意思)???
  Group 2. Transience
STEADY  =    T
(这上面东东是啥意思)???
  Group 3. X-Direction Grid Spacing
CARTES  =    T
NX      =      27
XULAST  = 1.000000E+00
XFRAC ( 1) =  8.392973E-02 ;XFRAC ( 2) =  1.554038E-01
XFRAC ( 3) =  2.138476E-01 ;XFRAC ( 4) =  2.584756E-01
XFRAC ( 5) =  2.880753E-01 ;XFRAC ( 6) =  3.000000E-01
XFRAC ( 7) =  3.055556E-01 ;XFRAC ( 8) =  3.222222E-01
XFRAC ( 9) =  3.500000E-01 ;XFRAC (10) =  3.777778E-01
XFRAC (11) =  3.944445E-01 ;XFRAC (12) =  4.000000E-01
XFRAC (13) =  4.152292E-01 ;XFRAC (14) =  4.461664E-01
XFRAC (15) =  4.883226E-01 ;XFRAC (16) =  5.399504E-01
XFRAC (17) =  6.000000E-01 ;XFRAC (18) =  6.250000E-01
XFRAC (19) =  6.500000E-01 ;XFRAC (20) =  6.750000E-01
XFRAC (21) =  7.000000E-01 ;XFRAC (22) =  7.144361E-01
XFRAC (23) =  7.360902E-01 ;XFRAC (24) =  7.685714E-01
XFRAC (25) =  8.172933E-01 ;XFRAC (26) =  8.903760E-01
XFRAC ( 27) =  1.000000E+00
  Group 4. Y-Direction Grid Spacing
NY      =      15
YVLAST  = 9.999999E-01
YFRAC ( 1) =  4.000000E-02 ;YFRAC ( 2) =  9.000001E-02
YFRAC ( 3) =  1.400000E-01 ;YFRAC ( 4) =  2.150000E-01
YFRAC ( 5) =  2.900001E-01 ;YFRAC ( 6) =  3.650000E-01
YFRAC ( 7) =  4.400001E-01 ;YFRAC ( 8) =  5.400000E-01
YFRAC ( 9) =  6.150000E-01 ;YFRAC (10) =  6.900001E-01
YFRAC (11) =  7.650000E-01 ;YFRAC (12) =  8.400000E-01
YFRAC (13) =  8.900000E-01 ;YFRAC (14) =  9.400000E-01
YFRAC ( 15) =  1.000000E+00
  Group 5. Z-Direction Grid Spacing
PARAB   =    F
NZ      =      20
ZWLAST  = 5.000000E-01
ZFRAC ( 1) =  5.000000E-02 ;ZFRAC ( 2) =  1.000000E-01
ZFRAC ( 3) =  1.500000E-01 ;ZFRAC ( 4) =  2.000000E-01
ZFRAC ( 5) =  2.500000E-01 ;ZFRAC ( 6) =  3.000000E-01
ZFRAC ( 7) =  3.500000E-01 ;ZFRAC ( 8) =  4.000000E-01
ZFRAC ( 9) =  4.500000E-01 ;ZFRAC (10) =  5.000000E-01
ZFRAC (11) =  5.500000E-01 ;ZFRAC (12) =  6.000000E-01
ZFRAC (13) =  6.500000E-01 ;ZFRAC (14) =  7.000000E-01
ZFRAC (15) =  7.500000E-01 ;ZFRAC (16) =  8.000000E-01
ZFRAC (17) =  8.500000E-01 ;ZFRAC (18) =  9.000000E-01
ZFRAC (19) =  9.500000E-01 ;ZFRAC (20) =  1.000000E+00
  Group 6. Body-Fitted Coordinates
  Group 7. Variables: STOREd,SOLVEd,NAMEd
ONEPHS  =    T
NAME(  1) =P1   ;NAME(  3) =U1
NAME(  5) =V1   ;NAME(  7) =W1
NAME(147) =PRPS ;NAME(148) =TEM1
NAME(149) =LTLS ;NAME(150) =WDIS
    * Y in SOLUTN argument list denotes:
    * 1-stored 2-solved 3-whole-field
    * 4-point-by-point 5-explicit 6-harmonic averaging
SOLUTN(P1  ,Y,Y,Y,N,N,Y)
SOLUTN(U1  ,Y,Y,N,N,N,Y)
SOLUTN(V1  ,Y,Y,N,N,N,Y)
SOLUTN(W1  ,Y,Y,N,N,N,Y)
SOLUTN(PRPS,Y,N,N,N,N,N)
SOLUTN(TEM1,Y,Y,Y,N,N,Y)
SOLUTN(LTLS,Y,Y,Y,N,N,Y)
SOLUTN(WDIS,Y,N,N,N,N,Y)
PRPS    =     147
  Group 8. Terms & Devices
    * Y in TERMS argument list denotes:
    * 1-built-in source 2-convection 3-diffusion 4-transient
    * 5-first phase variable 6-interphase transport
TERMS (P1  ,Y,Y,Y,N,Y,N)
TERMS (U1  ,Y,Y,Y,N,Y,N)
TERMS (V1  ,Y,Y,Y,N,Y,N)
TERMS (W1  ,Y,Y,Y,N,Y,N)
TERMS (TEM1,Y,Y,Y,N,Y,N)
TERMS (LTLS,N,N,Y,N,Y,N)
DIFCUT  = 5.000000E-01 ;ZDIFAC = 1.000000E+00
GALA    =    F  ;ADDDIF =    F
NEWRH1  =    T
NEWENL  =    T
NEWENT  =    T
ISOLX   =      -1 ;ISOLY  =      -1 ;ISOLZ  =      -1
  Group 9. Properties
RHO1    = GRND5        ;TMP1   = 0.000000E+00
EL1     = GRND1
TSURR   = 0.000000E+00 ;TEMP0  = 2.730000E+02
PRESS0  = 1.000000E+05
DVO1DT  = 3.330000E-03
RHO1A   = 0.000000E+00 ;RHO1B  = 3.484300E-03
RHO1C   = 7.142900E-01
DRH1DP  = GRND5
EL1A    = 0.000000E+00 ;EL1B   = 1.000000E+00
EL1C    = 0.000000E+00
ENUL    = GRND2        ;ENUT   = GRND8
ENULA   =-4.946790E-06 ;ENULB  = 4.583940E-08
ENULC   = 8.097400E-11
ENUTA   = 0.000000E+00 ;ENUTB  = 0.000000E+00
ENUTC   = 0.000000E+00
IENUTA  =       0
PRNDTL(U1  ) =  1.000000E+00 RNDTL(V1  ) =  1.000000E+00
PRNDTL(W1  ) =  1.000000E+00 RNDTL(TEM1) = -2.630000E-02
PRNDTL(LTLS) =  1.000000E+00
PRT   (U1  ) =  1.000000E+00 RT   (V1  ) =  1.000000E+00
PRT   (W1  ) =  1.000000E+00 ;PRT   (TEM1) =  1.000000E+00
PRT   (LTLS) =  1.000000E+10
CP1     = 1.004000E+03 ;CP2    = 4.181800E+03
  Group 10.Inter-Phase Transfer Processes
  Group 11.Initialise Var/Porosity Fields
FIINIT(P1  ) =  1.000000E-10 ;FIINIT(U1  ) =  1.000000E-10
FIINIT(V1  ) =  1.000000E-10 ;FIINIT(W1  ) =  1.000000E-10
FIINIT(PRPS) =  1.000000E-10 ;FIINIT(TEM1) =  2.000000E+01
FIINIT(LTLS) =  1.000000E-10 ;FIINIT(WDIS) =  5.000000E-02
   Parent VR object for this patch is: FENCE
PATCH(OB1     ,INIVAL,   7,  12,   1,  15,   1,  10,   1,   1)
INIT(OB1     ,PRPS, 0.000000E+00, 1.000000E+02)
   Parent VR object for this patch is: CLY
PATCH(OB2     ,INIVAL,  18,  21,   2,   3,   1,  20,   1,   1)
INIT(OB2     ,PRPS, 0.000000E+00, 1.000000E+02)
   Parent VR object for this patch is: B3
PATCH(OB3     ,INIVAL,  18,  21,   8,   8,   1,  20,   1,   1)
INIT(OB3     ,PRPS, 0.000000E+00, 1.000000E+02)
   Parent VR object for this patch is: B4
PATCH(OB4     ,INIVAL,  18,  21,  13,  14,   1,  20,   1,   1)
INIT(OB4     ,PRPS, 0.000000E+00, 1.000000E+02)
INIADD  =    F
FSWEEP  =       1
NAMFI   =CHAM
  Group 12. Patchwise adjustment of terms
  Patches for this group are printed with those
  for Group 13.
  Their names begin either with GP12 or &
  Group 13. Boundary & Special Sources
   Parent VR object for this patch is: OUTLET
PATCH(OB5     ,EAST  ,  27,  27,   1,  15,   1,  20,   1,   1)
COVAL(OB5     ,P1  , 1.000000E+03, 0.000000E+00)
COVAL(OB5     ,U1  , 0.000000E+00, 0.000000E+00)
COVAL(OB5     ,V1  , 0.000000E+00, 0.000000E+00)
COVAL(OB5     ,W1  , 0.000000E+00, 0.000000E+00)
COVAL(OB5     ,TEM1, 0.000000E+00, 2.000000E+01)
   Parent VR object for this patch is: INLET
PATCH(OB6     ,WEST  ,   1,   1,   1,  15,   1,  20,   1,   1)
COVAL(OB6     ,P1  , FIXFLU      , 1.189181E-01)
COVAL(OB6     ,U1  , 0.000000E+00, 1.000000E-01)
COVAL(OB6     ,V1  , 0.000000E+00, 0.000000E+00)
COVAL(OB6     ,W1  , 0.000000E+00, 0.000000E+00)
COVAL(OB6     ,TEM1, 0.000000E+00, 2.000000E+01)
PATCH(OC1     ,VOLUME,   7,  12,   1,  15,   1,  10,   1,   1)
COVAL(OC1     ,TEM1, FIXVAL      , 3.000000E+02)
PATCH(OC2     ,VOLUME,  18,  21,   2,   3,   1,  20,   1,   1)
PATCH(OC3     ,VOLUME,  18,  21,   8,   8,   1,  20,   1,   1)
PATCH(OC4     ,VOLUME,  18,  21,  13,  14,   1,  20,   1,   1)
XCYCLE  =    F
EGWF    =    T
WALLCO  = GRND2
  Group 14. Downstream Pressure For PARAB
  Group 15. Terminate Sweeps
LSWEEP  =     200 ;ISWC1  =       1
LITHYD  =     1 ;LITFLX =     1 ;LITC   =     1 ;ITHC1  =     1
SELREF  =    T
RESFAC  = 1.000000E-03
  Group 16. Terminate Iterations
LITER (P1  ) =     20 ;LITER (U1  ) =   10
LITER (V1  ) =     10 ;LITER (W1  ) =   10
LITER (TEM1) =     20 ;LITER (LTLS) = 1000
ENDIT (P1  ) =  1.000000E-03 ;ENDIT (U1  ) =  1.000000E-03
ENDIT (V1  ) =  1.000000E-03 ;ENDIT (W1  ) =  1.000000E-03
ENDIT (TEM1) =  1.000000E-03 ;ENDIT (LTLS) =  1.000000E-03
  Group 17. Relaxation
RELAX(P1  ,LINRLX, 1.000000E+00)
RELAX(U1  ,FALSDT, 1.000000E-01)
RELAX(V1  ,FALSDT, 1.000000E-01)
RELAX(W1  ,FALSDT, 1.000000E-01)
RELAX(PRPS,LINRLX, 1.000000E+00)
RELAX(TEM1,FALSDT, 1.000000E+02)
RELAX(LTLS,LINRLX, 1.000000E+00)
RELAX(WDIS,LINRLX, 1.000000E+00)
OVRRLX  = 0.000000E+00
EXPERT  =    F  ;NNORSL =    F
  Group 18. Limits
VARMAX(P1  ) = 1.000000E+10 ;VARMIN(P1  ) =-1.000000E+10
VARMAX(U1  ) = 1.000000E+06 ;VARMIN(U1  ) =-1.000000E+06
VARMAX(V1  ) = 1.000000E+06 ;VARMIN(V1  ) =-1.000000E+06
VARMAX(W1  ) = 1.000000E+06 ;VARMIN(W1  ) =-1.000000E+06
VARMAX(PRPS) = 1.000000E+10 ;VARMIN(PRPS) =-1.000000E+10
VARMAX(TEM1) = 1.000000E+10 ;VARMIN(TEM1) =-1.000000E+10
VARMAX(LTLS) = 1.000000E+10 ;VARMIN(LTLS) =-1.000000E+10
VARMAX(WDIS) = 1.000000E+10 ;VARMIN(WDIS) =-1.000000E+10
  Group 19. EARTH Calls To GROUND Station
GENK    =    T
ASAP    =    T
ISKINA  =       5 ;ISKINB =       4
GEN1    =     681
SPEDAT(SET,OBJNAM,^OB1,C,FENCE)
SPEDAT(SET,IGESTYPE,^OB1,C,BLOCKAGE)
SPEDAT(SET,OBJNAM,^OC1,C,FENCE)
SPEDAT(SET,IGESTYPE,^OC1,C,BLOCKAGE)
SPEDAT(SET,OBJNAM,^OB2,C,CLY)
SPEDAT(SET,IGESTYPE,^OB2,C,BLOCKAGE)
SPEDAT(SET,OBJNAM,^OC2,C,CLY)
SPEDAT(SET,IGESTYPE,^OC2,C,BLOCKAGE)
SPEDAT(SET,OBJNAM,^OB3,C,B3)
SPEDAT(SET,IGESTYPE,^OB3,C,BLOCKAGE)
SPEDAT(SET,OBJNAM,^OC3,C,B3)
SPEDAT(SET,IGESTYPE,^OC3,C,BLOCKAGE)
SPEDAT(SET,OBJNAM,^OB4,C,B4)
SPEDAT(SET,IGESTYPE,^OB4,C,BLOCKAGE)
SPEDAT(SET,OBJNAM,^OC4,C,B4)
SPEDAT(SET,IGESTYPE,^OC4,C,BLOCKAGE)
SPEDAT(SET,OBJNAM,^OB5,C,OUTLET)
SPEDAT(SET,IGESTYPE,^OB5,C,OUTLET)
SPEDAT(SET,OBJNAM,^OB6,C,INLET)
SPEDAT(SET,IGESTYPE,^OB6,C,INLET)
SPEDAT(SET,MATERIAL,0,L,T)
SPEDAT(SET,MATERIAL,100,L,T)
  Group 20. Preliminary Printout
ECHO    =    T
  Group 21. Print-out of Variables
INIFLD  =    F  ;SUBWGR =    F
    * Y in OUTPUT argument list denotes:
    * 1-field 2-correction-eq. monitor 3-selective dumping
    * 4-whole-field residual 5-spot-value table 6-residual table
OUTPUT(P1  ,Y,Y,Y,N,Y,Y)
OUTPUT(U1  ,Y,Y,Y,N,Y,Y)
OUTPUT(V1  ,Y,Y,Y,N,Y,Y)
OUTPUT(W1  ,Y,Y,Y,N,Y,Y)
OUTPUT(PRPS,Y,N,Y,N,N,N)
OUTPUT(TEM1,Y,N,Y,Y,Y,Y)
OUTPUT(LTLS,Y,N,Y,Y,N,Y)
OUTPUT(WDIS,Y,N,N,N,N,N)
  Group 22. Monitor Print-Out
IXMON   =      15 ;IYMON  =       1 ;IZMON  =      10
NPRMON  =   10000 ;NPRMNT =       1 ;TSTSWP =   10001
UWATCH  =    F  ;USTEER =    F
HIGHLO  =    F
  Group 23.Field Print-Out & Plot Control
NPRINT  =     200 ;NUMCLS =       5
NXPRIN  =       5 ;IXPRF  =       1 ;IXPRL  =      27
NYPRIN  =       3 ;IYPRF  =       1 ;IYPRL  =      15
NZPRIN  =       4 ;IZPRF  =       1 ;IZPRL  =   10000
XZPR    =    F  ;YZPR   =    F
IPLTF   =       1 ;IPLTL  =     200 ;NPLT   =      10
ISWPRF  =       1 ;ISWPRL =   10000
ITABL   =       1 ;IPROF  =       1
ABSIZ   = 5.000000E-01 ;ORSIZ  = 4.000000E-01
NTZPRF  =       1 ;NCOLPF =      50
ICHR    =       2 ;NCOLCO =      45 ;NROWCO =      20
   No PATCHes yet used for this Group
  Group 24. Dumps For Restarts
SAVE    =    T  ;AUTOPS =    F  ;NOWIPE =    T
NSAVE   =CHAM
*** grid-geometry information ***
X-coordinates of the cell centres
    4.196E-02   1.197E-01   1.846E-01   2.362E-01   2.733E-01
    2.940E-01   3.028E-01   3.139E-01   3.361E-01   3.639E-01
    3.861E-01   3.972E-01   4.076E-01   4.307E-01   4.672E-01
    5.141E-01   5.700E-01   6.125E-01   6.375E-01   6.625E-01
    6.875E-01   7.072E-01   7.253E-01   7.523E-01   7.929E-01
    8.538E-01   9.452E-01
Y-coordinates of the cell centres
    2.000E-02   6.500E-02   1.150E-01   1.775E-01   2.525E-01
    3.275E-01   4.025E-01   4.900E-01   5.775E-01   6.525E-01
    7.275E-01   8.025E-01   8.650E-01   9.150E-01   9.700E-01
Z-coordinates of the cell centres
    1.250E-02   3.750E-02   6.250E-02   8.750E-02   1.125E-01
    1.375E-01   1.625E-01   1.875E-01   2.125E-01   2.375E-01
    2.625E-01   2.875E-01   3.125E-01   3.375E-01   3.625E-01
    3.875E-01   4.125E-01   4.375E-01   4.625E-01   4.875E-01
X-coordinates of the (higher) cell faces
    8.393E-02   1.554E-01   2.138E-01   2.585E-01   2.881E-01
    3.000E-01   3.056E-01   3.222E-01   3.500E-01   3.778E-01
    3.944E-01   4.000E-01   4.152E-01   4.462E-01   4.883E-01
    5.400E-01   6.000E-01   6.250E-01   6.500E-01   6.750E-01
    7.000E-01   7.144E-01   7.361E-01   7.686E-01   8.173E-01
    8.904E-01   1.000E+00
Y-coordinates of the (higher) cell faces
    4.000E-02   9.000E-02   1.400E-01   2.150E-01   2.900E-01
    3.650E-01   4.400E-01   5.400E-01   6.150E-01   6.900E-01
    7.650E-01   8.400E-01   8.900E-01   9.400E-01   1.000E+00
Z-coordinates of the (higher) cell faces
    2.500E-02   5.000E-02   7.500E-02   1.000E-01   1.250E-01
    1.500E-01   1.750E-01   2.000E-01   2.250E-01   2.500E-01
    2.750E-01   3.000E-01   3.250E-01   3.500E-01   3.750E-01
    4.000E-01   4.250E-01   4.500E-01   4.750E-01   5.000E-01
--- INTEGRATION OF EQUATIONS BEGINS ---
isolx,y,z set to zero in solver as precaution
for variable LTLS at sweep            1
No. of whole-field variables has changed
from no.=       3   to no.=       2
TIME STP=     1 SWEEP NO=   200 ZSLAB NO=     4 ITERN NO=     1
FLOW FIELD AT ITHYD=   1, IZ=   4, ISWEEP= 200, ISTEP=    1
FIELD VALUES OF P1
IY=  15   4.666E-02   5.544E-02   .........  -3.325E-03  -1.487E-03
IY=  12   4.665E-02   5.532E-02   .........  -2.840E-03  -9.664E-04
IY=   9   4.673E-02   5.541E-02   .........  -2.947E-03  -9.597E-04
IY=   6   4.673E-02   5.542E-02   .........  -1.631E-03  -1.012E-03
IY=   3   4.662E-02   5.519E-02   .........  -3.471E-03   .........
  IX=       1           6          11          16          21
IY=  15  -2.653E-03
IY=  12  -2.265E-03
IY=   9  -2.613E-03
IY=   6  -2.791E-03
IY=   3  -2.439E-03
  IX=      26
FIELD VALUES OF U1
IY=  15   8.883E-02   .........   .........   5.081E-03   6.285E-02
IY=  12   8.882E-02   .........   .........  -3.860E-02  -2.747E-02
IY=   9   8.882E-02   .........   .........  -3.853E-02  -2.818E-02
IY=   6   8.881E-02   .........   .........  -4.645E-02  -2.647E-02
IY=   3   8.882E-02   .........   .........   1.041E-02   .........
  IX=       1           6          11          16          21
IY=  15   3.134E-02
IY=  12  -4.395E-02
IY=   9  -4.367E-02
IY=   6  -4.585E-02
IY=   3  -2.858E-02
  IX=      26
FIELD VALUES OF V1
IY=  14  -3.634E-05   8.662E-06   .........  -3.993E-04   .........
IY=  11  -5.714E-06  -1.298E-04   .........  -4.675E-04  -9.919E-03
IY=   8   1.615E-05  -8.820E-06   .........  -9.632E-04   .........
IY=   5   2.478E-05   2.251E-04   .........  -3.839E-03   8.378E-04
IY=   2   1.623E-05   2.112E-04   .........  -3.620E-03   .........
  IX=       1           6          11          16          21
IY=  14  -1.503E-02
IY=  11  -7.009E-03
IY=   8   1.247E-03
IY=   5   1.192E-06
IY=   2   1.745E-02
  IX=      26
FIELD VALUES OF W1
IY=  15   1.394E-02   5.404E-02   .........   1.038E-02  -2.874E-03
IY=  12   1.399E-02   5.409E-02   .........   1.550E-03   7.574E-03
IY=   9   1.401E-02   5.415E-02   .........   1.056E-02   9.979E-03
IY=   6   1.402E-02   5.415E-02   .........   2.216E-02   1.368E-02
IY=   3   1.396E-02   5.404E-02   .........  -7.607E-05   .........
  IX=       1           6          11          16          21
IY=  15   9.482E-03
IY=  12  -3.442E-04
IY=   9   4.918E-03
IY=   6   6.284E-03
IY=   3   1.406E-02
  IX=      26
FIELD VALUES OF PRPS
IY=  15   1.000E-10   1.000E-10   1.000E+02   1.000E-10   1.000E-10
IY=  12   1.000E-10   1.000E-10   1.000E+02   1.000E-10   1.000E-10
IY=   9   1.000E-10   1.000E-10   1.000E+02   1.000E-10   1.000E-10
IY=   6   1.000E-10   1.000E-10   1.000E+02   1.000E-10   1.000E-10
IY=   3   1.000E-10   1.000E-10   1.000E+02   1.000E-10   1.000E+02
  IX=       1           6          11          16          21
IY=  15   1.000E-10
IY=  12   1.000E-10
IY=   9   1.000E-10
IY=   6   1.000E-10
IY=   3   1.000E-10
  IX=      26
FIELD VALUES OF TEM1
IY=  15   2.000E+01   1.303E+02   3.000E+02   4.638E+01   4.932E+01
IY=  12   2.000E+01   1.312E+02   3.000E+02   3.861E+01   2.637E+01
IY=   9   2.000E+01   1.311E+02   3.000E+02   4.027E+01   2.252E+01
IY=   6   2.000E+01   1.310E+02   3.000E+02   2.893E+01   2.225E+01
IY=   3   2.000E+01   1.315E+02   3.000E+02   4.376E+01   2.699E+01
  IX=       1           6          11          16          21
IY=  15   3.805E+01
IY=  12   2.637E+01
IY=   9   2.283E+01
IY=   6   2.218E+01
IY=   3   3.839E+01
  IX=      26
FIELD VALUES OF LTLS
IY=  15   9.184E+04   3.357E+03   .........   2.701E+03   2.047E+03
IY=  12   9.063E+04   3.323E+03   .........   4.601E+03   5.534E+03
IY=   9   8.684E+04   3.194E+03   .........   4.951E+03   5.931E+03
IY=   6   9.128E+04   3.353E+03   .........   6.247E+03   1.016E+04
IY=   3   1.013E+05   3.700E+03   .........   3.413E+03   .........
  IX=       1           6          11          16          21
IY=  15   1.128E+04
IY=  12   1.315E+04
IY=   9   1.388E+04
IY=   6   1.476E+04
IY=   3   1.304E+04
  IX=      26
FIELD VALUES OF WDIS
IY=  15   7.795E-01   6.012E-03   .........   1.171E-01   3.941E-02
IY=  12   7.556E-01   6.016E-03   .........   1.234E-01   5.024E-02
IY=   9   7.724E-01   6.016E-03   .........   1.360E-01   5.097E-02
IY=   6   7.395E-01   6.016E-03   .........   1.313E-01   2.354E-01
IY=   3   7.273E-01   6.015E-03   .........   1.114E-01   .........
  IX=       1           6          11          16          21
IY=  15   2.913E-01
IY=  12   4.093E-01
IY=   9   4.783E-01
IY=   6   6.903E-01
IY=   3   3.031E-01
  IX=      26
TIME STP=     1 SWEEP NO=   200 ZSLAB NO=     8 ITERN NO=     1
FLOW FIELD AT ITHYD=   1, IZ=   8, ISWEEP= 200, ISTEP=    1
FIELD VALUES OF P1
IY=  15   4.369E-02   4.680E-02   .........  -2.523E-03  -5.324E-03
IY=  12   4.367E-02   4.671E-02   .........  -3.573E-03  -2.287E-03
IY=   9   4.372E-02   4.676E-02   .........  -3.359E-03  -1.488E-03
IY=   6   4.372E-02   4.677E-02   .........  -3.332E-03  -1.481E-03
IY=   3   4.367E-02   4.665E-02   .........  -2.336E-03   .........
  IX=       1           6          11          16          21
IY=  15  -1.792E-03
IY=  12  -2.874E-03
IY=   9  -3.204E-03
IY=   6  -3.810E-03
IY=   3  -4.161E-03
  IX=      26
FIELD VALUES OF U1
IY=  15   9.460E-02   .........   .........   6.096E-02   1.504E-01
IY=  12   9.460E-02   .........   .........   3.516E-02   8.123E-02
IY=   9   9.460E-02   .........   .........   4.401E-02   7.510E-02
IY=   6   9.460E-02   .........   .........  -1.275E-02   3.063E-02
IY=   3   9.460E-02   .........   .........   4.543E-02   .........
  IX=       1           6          11          16          21
IY=  15   1.419E-01
IY=  12   2.139E-02
IY=   9   6.571E-02
IY=   6   6.155E-02
IY=   3   9.530E-03
  IX=      26
FIELD VALUES OF V1
IY=  14  -3.894E-05  -3.829E-05   .........   1.795E-02   .........
IY=  11  -3.721E-05  -1.557E-04   .........   3.014E-02  -1.957E-03
IY=   8   1.163E-05   3.937E-07   .........   1.206E-02   .........
IY=   5   6.146E-05   2.661E-04   .........  -8.625E-03  -1.758E-02
IY=   2   4.123E-05   2.433E-04   .........  -9.683E-03   .........
  IX=       1           6          11          16          21
IY=  14  -2.583E-02
IY=  11  -1.705E-02
IY=   8  -1.224E-02
IY=   5  -7.532E-03
IY=   2   8.499E-04
  IX=      26
FIELD VALUES OF W1
IY=  15   2.337E-02   1.400E-01   .........  -1.827E-03  -3.482E-02
IY=  12   2.344E-02   1.401E-01   .........   1.490E-02  -2.185E-03
IY=   9   2.349E-02   1.403E-01   .........   1.464E-02  -2.248E-03
IY=   6   2.350E-02   1.402E-01   .........   2.336E-02   2.342E-02
IY=   3   2.338E-02   1.399E-01   .........  -2.346E-02   .........
  IX=       1           6          11          16          21
IY=  15  -3.280E-02
IY=  12   1.974E-02
IY=   9   5.490E-03
IY=   6   1.180E-02
IY=   3   8.168E-03
  IX=      26
  IX=       1           6          11          16          21
IY=  15   1.000E-10
IY=  12   1.000E-10
IY=   9   1.000E-10
IY=   6   1.000E-10
IY=   3   1.000E-10
  IX=      26
IY=  15   2.000E+01   1.130E+02   3.000E+02   6.645E+01   5.133E+01
IY=  12   2.000E+01   1.135E+02   3.000E+02   3.625E+01   4.028E+01
IY=   9   2.000E+01   1.134E+02   3.000E+02   4.347E+01   4.694E+01
IY=   6   2.000E+01   1.134E+02   3.000E+02   4.030E+01   3.685E+01
IY=   3   2.000E+01   1.137E+02   3.000E+02   5.822E+01   2.695E+01
  IX=       1           6          11          16          21
IY=  15   4.308E+01
IY=  12   3.538E+01
IY=   9   3.304E+01
IY=   6   2.855E+01
IY=   3   3.387E+01
  IX=      26
IY=  15   1.044E+05   4.679E+03   .........   7.508E+03   2.400E+03
IY=  12   1.031E+05   4.636E+03   .........   1.015E+04   6.803E+03
IY=   9   9.890E+04   4.467E+03   .........   1.054E+04   7.272E+03
IY=   6   1.039E+05   4.688E+03   .........   1.258E+04   1.270E+04
IY=   3   1.153E+05   5.163E+03   .........   8.714E+03   .........
  IX=       1           6          11          16          21
IY=  15   1.160E+04
IY=  12   1.377E+04
IY=   9   1.461E+04
IY=   6   1.562E+04
IY=   3   1.355E+04
  IX=      26
IY=  15   5.769E-01   6.043E-03   .........   8.763E-02   4.469E-02
IY=  12   5.680E-01   6.047E-03   .........   1.036E-01   5.162E-02
IY=   9   5.716E-01   6.047E-03   .........   1.088E-01   5.255E-02
IY=   6   5.582E-01   6.047E-03   .........   1.147E-01   2.565E-01
IY=   3   5.545E-01   6.046E-03   .........   8.758E-02   .........
  IX=       1           6          11          16          21
IY=  15   2.999E-01
IY=  12   4.349E-01
IY=   9   5.262E-01
IY=   6   8.099E-01
IY=   3   3.131E-01
  IX=      26
TIME STP=     1 SWEEP NO=   200 ZSLAB NO=    12 ITERN NO=     1
FLOW FIELD AT ITHYD=   1, IZ=  12, ISWEEP= 200, ISTEP=    1
FIELD VALUES OF P1
IY=  15   4.004E-02   7.102E-03  -1.013E-03   7.751E-04  -9.596E-03
IY=  12   4.001E-02   7.126E-03  -7.676E-04  -1.085E-03  -8.817E-03
IY=   9   4.002E-02   7.046E-03  -8.599E-04  -1.249E-03  -6.655E-03
IY=   6   4.003E-02   7.112E-03  -6.558E-04  -2.025E-03  -3.360E-03
IY=   3   4.004E-02   7.144E-03  -9.522E-04   3.667E-03   .........
  IX=       1           6          11          16          21
IY=  15  -1.558E-04
IY=  12  -1.893E-03
IY=   9  -1.141E-03
IY=   6  -1.903E-03
IY=   3  -1.758E-03
  IX=      26
FIELD VALUES OF U1
IY=  15   1.046E-01   2.144E-01   1.684E-01   1.937E-01   2.503E-01
IY=  12   1.046E-01   2.137E-01   1.627E-01   1.865E-01   2.358E-01
IY=   9   1.046E-01   2.138E-01   1.624E-01   1.835E-01   2.241E-01
IY=   6   1.046E-01   2.134E-01   1.594E-01   1.678E-01   1.921E-01
IY=   3   1.046E-01   2.143E-01   1.682E-01   1.383E-01   .........
  IX=       1           6          11          16          21
IY=  15   2.002E-01
IY=  12   1.662E-01
IY=   9   1.781E-01
IY=   6   1.794E-01
IY=   3   1.339E-01
  IX=      26
FIELD VALUES OF V1
IY=  14  -5.582E-05  -7.551E-05   5.055E-04   1.690E-02   .........
IY=  11  -8.375E-05  -1.803E-04   9.517E-04  -4.057E-03   1.455E-02
IY=   8   1.081E-05   4.036E-05  -2.758E-05   1.902E-02   .........
IY=   5   1.088E-04   3.785E-04   7.010E-04   2.142E-03   1.312E-03
IY=   2   1.228E-04   3.100E-04  -3.053E-04   6.713E-03   .........
  IX=       1           6          11          16          21
IY=  14  -3.042E-03
IY=  11   1.818E-02
IY=   8  -2.445E-02
IY=   5  -7.249E-03
IY=   2  -4.203E-02
  IX=      26
FIELD VALUES OF W1
IY=  15   2.231E-02   1.293E-01   2.826E-02  -4.306E-02  -3.359E-02
IY=  12   2.245E-02   1.303E-01   3.238E-02  -2.519E-02  -5.560E-03
IY=   9   2.250E-02   1.306E-01   3.313E-02  -2.179E-02  -9.955E-03
IY=   6   2.252E-02   1.308E-01   3.471E-02  -8.206E-03  -3.599E-03
IY=   3   2.234E-02   1.293E-01   2.784E-02  -5.742E-02   .........
  IX=       1           6          11          16          21
IY=  15  -2.279E-02
IY=  12   4.329E-03
IY=   9  -4.360E-03
IY=   6  -4.325E-03
IY=   3   9.485E-03
  IX=      26
IY=  15   1.000E-10   1.000E-10   1.000E-10   1.000E-10   1.000E-10
IY=  12   1.000E-10   1.000E-10   1.000E-10   1.000E-10   1.000E-10
IY=   9   1.000E-10   1.000E-10   1.000E-10   1.000E-10   1.000E-10
IY=   6   1.000E-10   1.000E-10   1.000E-10   1.000E-10   1.000E-10
IY=   3   1.000E-10   1.000E-10   1.000E-10   1.000E-10   1.000E+02
  IX=       1           6          11          16          21
IY=  15   1.000E-10
IY=  12   1.000E-10
IY=   9   1.000E-10
IY=   6   1.000E-10
IY=   3   1.000E-10
  IX=      26
IY=  15   2.000E+01   2.627E+01   3.981E+01   3.544E+01   2.792E+01
IY=  12   2.000E+01   2.634E+01   4.055E+01   3.918E+01   3.199E+01
IY=   9   2.000E+01   2.635E+01   4.061E+01   4.086E+01   3.272E+01
IY=   6   2.000E+01   2.635E+01   4.091E+01   4.226E+01   3.598E+01
IY=   3   2.000E+01   2.632E+01   3.991E+01   3.390E+01   2.686E+01
  IX=       1           6          11          16          21
IY=  15   2.702E+01
IY=  12   3.153E+01
IY=   9   3.168E+01
IY=   6   3.049E+01
IY=   3   3.262E+01
  IX=      26
IY=  15   1.228E+05   5.345E+04   3.104E+04   2.068E+04   3.010E+03
IY=  12   1.214E+05   5.319E+04   3.166E+04   2.455E+04   8.791E+03
IY=   9   1.166E+05   5.156E+04   3.106E+04   2.490E+04   9.360E+03
IY=   6   1.225E+05   5.411E+04   3.281E+04   2.840E+04   1.661E+04
IY=   3   1.358E+05   5.912E+04   3.456E+04   2.322E+04   .........
  IX=       1           6          11          16          21
IY=  15   1.202E+04
IY=  12   1.459E+04
IY=   9   1.558E+04
IY=   6   1.677E+04
IY=   3   1.420E+04
  IX=      26
IY=  15   6.173E-01   5.757E-02   4.409E-02   9.228E-02   5.257E-02
IY=  12   6.052E-01   5.766E-02   4.435E-02   1.112E-01   5.281E-02
IY=   9   6.075E-01   5.769E-02   4.444E-02   1.157E-01   5.404E-02
IY=   6   5.926E-01   5.770E-02   4.455E-02   1.315E-01   2.580E-01
IY=   3   5.904E-01   5.760E-02   4.413E-02   8.762E-02   .........
  IX=       1           6          11          16          21
IY=  15   3.133E-01
IY=  12   4.758E-01
IY=   9   6.225E-01
IY=   6   1.114E+00
IY=   3   3.277E-01
  IX=      26
TIME STP=     1 SWEEP NO=   200 ZSLAB NO=    16 ITERN NO=     1
FLOW FIELD AT ITHYD=   1, IZ=  16, ISWEEP= 200, ISTEP=    1
FIELD VALUES OF P1
IY=  15   3.734E-02   2.143E-02   1.320E-02   1.138E-02  -1.647E-02
IY=  12   3.730E-02   2.098E-02   1.179E-02   6.969E-03  -1.528E-02
IY=   9   3.728E-02   2.078E-02   1.140E-02   6.659E-03  -1.307E-02
IY=   6   3.730E-02   2.071E-02   1.082E-02   4.032E-03  -6.375E-03
IY=   3   3.738E-02   2.150E-02   1.346E-02   1.690E-02   .........
  IX=       1           6          11          16          21
IY=  15   5.285E-05
IY=  12  -1.170E-03
IY=   9   1.458E-05
IY=   6  -7.478E-05
IY=   3  -1.962E-03
  IX=      26
FIELD VALUES OF U1
IY=  15   1.096E-01   1.991E-01   2.330E-01   2.404E-01   3.000E-01
IY=  12   1.098E-01   2.008E-01   2.380E-01   2.547E-01   2.962E-01
IY=   9   1.098E-01   2.015E-01   2.392E-01   2.537E-01   2.913E-01
IY=   6   1.099E-01   2.018E-01   2.416E-01   2.656E-01   2.838E-01
IY=   3   1.097E-01   1.990E-01   2.318E-01   1.647E-01   .........
  IX=       1           6          11          16          21
IY=  15   2.236E-01
IY=  12   2.274E-01
IY=   9   2.279E-01
IY=   6   2.369E-01
IY=   3   1.655E-01
  IX=      26
FIELD VALUES OF V1
IY=  14  -4.715E-05  -4.704E-04  -5.893E-04   2.269E-02   .........
IY=  11  -1.284E-04  -1.060E-03  -3.247E-03  -1.890E-02   8.830E-03
IY=   8   6.007E-05   4.812E-04   2.474E-03   3.284E-02   .........
IY=   5   2.111E-04   8.178E-04   1.443E-03   2.980E-03   5.032E-04
IY=   2   1.484E-04   1.312E-03   3.680E-03   1.469E-02   .........
  IX=       1           6          11          16          21
IY=  14  -1.705E-02
IY=  11   2.158E-02
IY=   8  -2.828E-02
IY=   5  -3.892E-03
IY=   2  -2.968E-02
  IX=      26
FIELD VALUES OF W1
IY=  15   1.228E-02   4.448E-02   2.290E-02  -1.839E-02  -2.106E-02
IY=  12   1.244E-02   4.563E-02   2.639E-02  -9.343E-03  -9.171E-03
IY=   9   1.247E-02   4.589E-02   2.732E-02  -7.583E-03  -4.877E-03
IY=   6   1.239E-02   4.619E-02   2.836E-02  -2.183E-03  -3.648E-03
IY=   3   1.226E-02   4.454E-02   2.287E-02  -2.013E-02   .........
  IX=       1           6          11          16          21
IY=  15  -6.920E-03
IY=  12  -2.023E-03
IY=   9  -2.203E-04
IY=   6  -3.828E-03
IY=   3   1.796E-02
  IX=      26
  IX=       1           6          11          16          21
IY=  15   1.000E-10
IY=  12   1.000E-10
IY=   9   1.000E-10
IY=   6   1.000E-10
IY=   3   1.000E-10
  IX=      26
IY=  15   2.000E+01   2.001E+01   2.049E+01   2.080E+01   2.063E+01
IY=  12   2.000E+01   2.001E+01   2.055E+01   2.111E+01   2.100E+01
IY=   9   2.000E+01   2.001E+01   2.056E+01   2.121E+01   2.112E+01
IY=   6   2.000E+01   2.001E+01   2.058E+01   2.144E+01   2.194E+01
IY=   3   2.000E+01   2.001E+01   2.050E+01   2.074E+01   2.678E+01
  IX=       1           6          11          16          21
IY=  15   2.108E+01
IY=  12   2.237E+01
IY=   9   2.278E+01
IY=   6   2.348E+01
IY=   3   2.350E+01
  IX=      26
IY=  15   1.396E+05   1.098E+05   8.194E+04   3.668E+04   3.625E+03
IY=  12   1.383E+05   1.096E+05   8.322E+04   4.178E+04   1.068E+04
IY=   9   1.331E+05   1.064E+05   8.147E+04   4.201E+04   1.135E+04
IY=   6   1.397E+05   1.117E+05   8.582E+04   4.706E+04   2.031E+04
IY=   3   1.546E+05   1.217E+05   9.128E+04   4.090E+04   .........
  IX=       1           6          11          16          21
IY=  15   1.233E+04
IY=  12   1.524E+04
IY=   9   1.636E+04
IY=   6   1.770E+04
IY=   3   1.470E+04
  IX=      26
IY=  15   1.062E+00   2.554E-01   1.793E-01   1.038E-01   5.774E-02
IY=  12   1.007E+00   2.578E-01   1.871E-01   1.275E-01   5.327E-02
IY=   9   1.023E+00   2.595E-01   1.899E-01   1.331E-01   5.476E-02
IY=   6   9.577E-01   2.590E-01   1.923E-01   1.607E-01   2.457E-01
IY=   3   9.492E-01   2.551E-01   1.812E-01   9.524E-02   .........
  IX=       1           6          11          16          21
IY=  15   3.272E-01
IY=  12   5.169E-01
IY=   9   7.651E-01
IY=   6   1.966E+00
IY=   3   3.420E-01
  IX=      26
TIME STP=     1 SWEEP NO=   200 ZSLAB NO=    20 ITERN NO=     1
FLOW FIELD AT ITHYD=   1, IZ=  20, ISWEEP= 200, ISTEP=    1
FIELD VALUES OF P1
IY=  15   3.671E-02   2.533E-02   1.853E-02   1.545E-02  -1.605E-02
IY=  12   3.661E-02   2.483E-02   1.684E-02   1.026E-02  -1.528E-02
IY=   9   3.660E-02   2.460E-02   1.640E-02   1.005E-02  -1.511E-02
IY=   6   3.660E-02   2.455E-02   1.567E-02   7.070E-03  -7.668E-03
IY=   3   3.668E-02   2.544E-02   1.878E-02   2.082E-02   .........
  IX=       1           6          11          16          21
IY=  15  -1.391E-03
IY=  12  -1.804E-03
IY=   9  -3.755E-04
IY=   6  -1.797E-04
IY=   3  -3.911E-03
  IX=      26
FIELD VALUES OF U1
IY=  15   1.105E-01   1.822E-01   2.100E-01   2.304E-01   2.922E-01
IY=  12   1.104E-01   1.850E-01   2.176E-01   2.480E-01   2.884E-01
IY=   9   1.109E-01   1.858E-01   2.192E-01   2.470E-01   2.945E-01
IY=   6   1.102E-01   1.869E-01   2.231E-01   2.625E-01   2.922E-01
IY=   3   1.099E-01   1.826E-01   2.093E-01   1.530E-01   .........
  IX=       1           6          11          16          21
IY=  15   2.219E-01
IY=  12   2.349E-01
IY=   9   2.369E-01
IY=   6   2.477E-01
IY=   3   1.457E-01
  IX=      26
FIELD VALUES OF V1
IY=  14  -1.914E-05  -6.559E-04  -1.100E-03   2.372E-02   .........
IY=  11  -1.459E-04  -1.506E-03  -4.797E-03  -2.406E-02   3.387E-03
IY=   8   1.349E-04   7.896E-04   3.564E-03   3.800E-02   .........
IY=   5   3.116E-04   1.228E-03   2.140E-03   3.948E-03   2.052E-03
IY=   2   2.000E-05   1.645E-03   5.076E-03   1.825E-02   .........
  IX=       1           6          11          16          21
IY=  14  -9.939E-03
IY=  11   1.902E-02
IY=   8  -2.630E-02
IY=   5  -2.078E-03
IY=   2  -3.622E-03
  IX=      26
FIELD VALUES OF W1
  IX=       1           6          11          16          21
IY=  15   1.000E-10
IY=  12   1.000E-10
IY=   9   1.000E-10
IY=   6   1.000E-10
IY=   3   1.000E-10
  IX=      26
IY=  15   2.000E+01   2.000E+01   2.000E+01   2.002E+01   2.010E+01
IY=  12   2.000E+01   2.000E+01   2.001E+01   2.003E+01   2.010E+01
IY=   9   2.000E+01   2.000E+01   2.001E+01   2.003E+01   2.017E+01
IY=   6   2.000E+01   2.000E+01   2.001E+01   2.004E+01   2.012E+01
IY=   3   2.000E+01   2.000E+01   2.000E+01   2.002E+01   2.675E+01
  IX=       1           6          11          16          21
IY=  15   2.030E+01
IY=  12   2.050E+01
IY=   9   2.087E+01
IY=   6   2.144E+01
IY=   3   2.199E+01
  IX=      26
IY=  15   1.462E+05   1.265E+05   9.783E+04   4.338E+04   3.834E+03
IY=  12   1.453E+05   1.267E+05   9.952E+04   4.912E+04   1.131E+04
IY=   9   1.401E+05   1.230E+05   9.736E+04   4.932E+04   1.203E+04
IY=   6   1.469E+05   1.290E+05   1.025E+05   5.501E+04   2.154E+04
IY=   3   1.621E+05   1.407E+05   1.093E+05   4.840E+04   .........
  IX=       1           6          11          16          21
IY=  15   1.232E+04
IY=  12   1.538E+04
IY=   9   1.657E+04
IY=   6   1.794E+04
IY=   3   1.477E+04
  IX=      26
IY=  15   6.459E+00   6.015E-01   2.593E-01   1.083E-01   5.903E-02
IY=  12   3.766E+00   6.345E-01   2.822E-01   1.341E-01   5.330E-02
IY=   9   7.034E+00   6.590E-01   2.906E-01   1.405E-01   5.497E-02
IY=   6   2.471E+00   6.469E-01   2.976E-01   1.732E-01   2.338E-01
IY=   3   2.222E+00   6.038E-01   2.660E-01   9.852E-02   .........
  IX=       1           6          11          16          21
IY=  15   3.325E-01
IY=  12   5.255E-01
IY=   9   8.387E-01
IY=   6   2.939E+00
IY=   3   3.473E-01
  IX=      26
TIME STP=     1 SWEEP NO=   200 ZSLAB NO=     1 ITERN NO=     1
Whole-field residuals before solution
with resref values determined by EARTH
& resfac= 1.000000E-03
  variable   resref  (res sum)/resref
     TEM1   2.776E-02   4.651E+03
     LTLS   6.173E-08   0.000E+00
!! Zero nett sources are not printed !!!
Nett source of U1   at patch named: OB5      (OUTLET        ) =-1.199E-02
Nett source of U1   at patch named: OB6      (INLET         ) = 5.946E-03
nett sum=-6.040403E-03 pos. sum= 5.946183E-03
neg. sum=-1.198659E-02
Nett source of V1   at patch named: OB5      (OUTLET        ) = 1.497E-04
nett sum= 1.497043E-04 pos. sum= 1.497043E-04
neg. sum= 0.000000E+00
Nett source of W1   at patch named: OB5      (OUTLET        ) = 3.216E-04
nett sum= 3.215984E-04 pos. sum= 3.215984E-04
Nett source of R1   at patch named: OB5      (OUTLET        ) =-5.950E-02
Nett source of R1   at patch named: OB6      (INLET         ) = 5.946E-02
nett sum=-4.300848E-05 pos. sum= 5.946181E-02
neg. sum=-5.950482E-02
Nett source of TEM1 at patch named: OB5      (OUTLET        ) =-1.790E+04
Nett source of TEM1 at patch named: OB6      (INLET         ) = 1.749E+04
nett sum=-4.040723E+02 pos. sum= 1.749200E+04
neg. sum=-1.789608E+04
spot values vs sweep or iteration number
    IXMON=    15    IYMON=     1    IZMON=    10 TIMESTEP=     1
   VARIABLE    1 = P1     2 = U1     3 = V1     4 = W1     5 = TEM1
     MINVAL= -1.252E-01  1.916E-03 -1.720E-02 -1.511E-01  2.000E+01
     MAXVAL=  1.116E-01  1.265E-01  1.087E-03 -2.620E-03  1.043E+02
     CELLAV= -6.954E-03  8.868E-02 -9.920E-03 -3.476E-02  8.320E+01
1.00 4..3.3....+3...+....+....+....+.5..+.5.5+.5..5.5..+
      3  2    3  2              5  5    5    4  4  4 4  5
0.90 +                       5    4  4 4  4            +
      .                    4  4 4                       .
0.80 +            3  4 5  5                            +
      .            4          2                         .
0.70 +       2            2    2  2  2                 +
      .               5                 2  2 2          .
0.60 +                                         2  2 2  2
      1       4  5 5  1                                 .
0.50 +                 3     1    1  1 1  1 1  1  1 1  1
      .       5  1         1    1                       .
0.40 +                 1                               +
      .    5       1                                    .
0.30 +                    3                            +
0.20 +                       3                         3
      .  5                                           3  .
0.10 +                         3                  3    +
      .                            3         3  3       .
0.00 5..4.1....+....+....+....+....+.3.3+.3..+....+....+
      0   .1   .2   .3   .4   .5   .6   .7   .8   .9  1.0
the abscissa is      ISWP.  min= 1.00E+00 max= 1.91E+02
residuals vs sweep or iteration number
     MINVAL=  8.814E+00  1.005E+01  1.127E+01  1.131E+01  8.495E+00
     MAXVAL=  1.573E+01  1.418E+01  1.459E+01  1.413E+01  9.434E+00
   VARIABLE    6 = LTLS
     MINVAL= -4.605E+01
     MAXVAL= -4.605E+01
1.00 1..4.+..5.+....+....+....+....+....+....+....+....+
      .    3                                            .
0.90 2    4  3                                         +
      .    5  2                                         .
0.80 +                                                 +
      .       4                                         .
0.70 +            3                                    +
      .               2                                 .
0.60 +            4                                    +
      .          2    3                                 .
0.50 +          4 5                                    +
      .          5    4 3                               .
0.40 +  1              2                               +
      3       1         4  3  2                         .
0.30 4                    4  4 3                       +
      .    1     1    5         4  3                    .
0.20 +            1    5          4  4    3            +
      .                    5          2 4  4 4  3       .
0.10 5  5            1 1  1    5            2  4  4    +
      .                       5 1  5    5       2  2 4  .
0.00 6..6.6..6.+6.6.+6.6.+6..6+6..6+.6.6+.6.6+.6..6.6..6
SATLIT RUN NUMBER =   1 ; LIBRARY REF.=  302
RUN COMPLETED AT 18:18:03 ON FRIDAY, 26 JULY 2002
MACHINE-CLOCK TIME OF RUN =     240 SECONDS.
TIME/(VARIABLES*CELLS*TSTEPS*SWEEPS*ITS) = 2.469E-05
发表于 2002-8-15 15:06:12 | 显示全部楼层
你的问题太多,我建议你不懂的可以先不用去管它。
你只需要知道输出的结果就可以了。你的结果不完全,要想将每一个点都打印出来,你可以在output按钮中设置。
祝你好运
发表于 2002-8-15 15:48:46 | 显示全部楼层
v1还没有收敛吧?
发表于 2002-8-15 16:09:56 | 显示全部楼层
请phoenics大侠详细说说关于输出结果的情况。有劳!
 楼主| 发表于 2002-8-15 21:27:08 | 显示全部楼层
有劳各位大虾提示一下,我想知道稳定以后的进口压差,
RESULT里面出现的好多IY和IX是什么东西?
发表于 2002-8-16 09:32:19 | 显示全部楼层
IX,IY分别指的是X,Y方向的层数,也就是X、Y方向上的第几个网格
 楼主| 发表于 2002-8-16 10:23:45 | 显示全部楼层
请问变量LTLS是什么东西?
从下面表格能看出什么来?
0.90 +                       5    4  4 4  4            +
      .                    4  4 4                       .
0.80 +            3  4 5  5                            +
      .            4          2                         .
0.70 +       2            2    2  2  2                 +
      .               5                 2  2 2          .
0.60 +                                         2  2 2  2
      1       4  5 5  1                                 .
      .       5  1         1    1                       .
0.40 +                 1                               +
      .    5       1                                    .
0.30 +                    3                            +
0.20 +                       3                         3
      .  5                                           3  .
0.10 +                         3                  3    +
      .                            3         3  3       .
   VARIABLE    6 = LTLS
     MINVAL= -4.605E+01
     MAXVAL= -4.605E+01
      .    3                                            .
0.90 2    4  3                                         +
      .    5  2                                         .
0.80 +                                                 +
      .       4                                         .
0.70 +            3                                    +
      .               2                                 .
0.60 +            4                                    +
      .          2    3                                 .
0.50 +          4 5                                    +
      .          5    4 3                               .
0.40 +  1              2                               +
      3       1         4  3  2                         .
0.30 4                    4  4 3                       +
      .    1     1    5         4  3                    .
0.20 +            1    5          4  4    3            +
      .                    5          2 4  4 4  3       .
      .                       5 1  5    5       2  2 4  .
再请phoenics大侠详细说说关于输出结果的情况。有劳!
^_^在交流中共同学习进步^_^
发表于 2002-8-16 10:49:09 | 显示全部楼层
上面的图就是计算时屏幕上的几条曲线,一个是计算值,一个是误差,1=p1,2=u1....
RESULT里有用的东西主要是
1、各点的计算值
2、nett sorce,即净源项,它是评价收敛的尺度。
 楼主| 发表于 2002-8-16 11:10:15 | 显示全部楼层
请问P1的单位是不是Pa
它好象非常小。例如 3E-3
但是我做实验时的测值是好几Pa
误差好象太大了
发表于 2002-8-16 15:18:25 | 显示全部楼层
这就很难说了,影响结果的因素太多了。
祝你好运吧!
 楼主| 发表于 2002-8-16 16:24:00 | 显示全部楼层
谢谢“非你客死”的答复
