查看: 3602|回复: 2
van leer 格式
发表于 2002-7-7 11:06:36 | 显示全部楼层 |阅读模式
如何消除VAN LEER 格式音速点的过冲。有一维程序就太好了
发表于 2002-7-8 09:21:45 | 显示全部楼层
van leer 格式
I am not sure whether this code is ok, you could have a try.
      program vl2
c...For the linear advection equation, performs the method described
c...in van Leer, Towards the Ultimate Conservative Difference Scheme.
c...II. Monotonicity and Conservation Combined in a Second-Order Method,
c...J. Comput. Phys., 14, 361-370 (1974).
      parameter (nmax=100,delta=.000001)
      real lambda,u(-2:nmax+2),h(0:nmax),u0(1:nmax+1),s(0:nmax)
      open(unit=9,file='vl2.out')
c...Read initial data samples.  Samples evenly spaced.
c...Data assumed periodic.
      open(unit=8,file='nb.dat',status='old')
      read(8,*) n, lambda, tfinal
      if(n.gt.nmax) then
        write(9,*) '****Too many data points****'
        close(unit=8)
        close(unit=9)
        stop
      endif
      if(n.lt.2) then
        write(9,*) '****Too few data points****'
        close(unit=8)
        close(unit=9)
        stop
      endif
      if(lambda.lt.0.01) then
        write(9,*) '****Lambda small or negative****'
        close(unit=8)
        close(unit=9)
        stop
      endif
      i=1
      read(8,*,err=1000,end=1000) xmin, u(1)
      do 10, i=2,n
        read(8,*,err=1000,end=1000) dummy, u(i)
10   continue
      i=n+1
      read(8,*,err=1000,end=1000) xmax, u(n+1)
      if(abs(u(n+1)-u(1)).gt..0001) then
        write(9,*) '****Data not periodic****'
        close(unit=8)
        close(unit=9)
        stop
      endif
      if(xmax.le.xmin+.0001) then
        write(9,*) '****Bad x-axis****'
        close(unit=8)
        close(unit=9)
        stop
      endif
      u(0) = u(n)
      u(-1) = u(n-1)
      u(-2) = u(n-2)
      u(n+2) = u(2)
      do 15, i=1,n+1
        u0(i) = u(i)
15   continue
      delta_x=(xmax-xmin)/real(n)
      delta_t=lambda*delta_x
      itert=nint(tfinal/delta_t)
      write(9,*) 'Final time requested: ', tfinal
      tfinal = real(itert)*delta_t
      write(9,*) 'Actual final time: ', tfinal
      write(9,*) 'delta_t = ', delta_t
      write(9,*) 'delta_x = ', delta_x
      write(9,*) 'lambda = ', lambda
      do 500, it=1,itert
      do 80, i=0,n
        if(abs(u(i+1)-u(i))+abs(u(i)-u(i-1)).gt..00001) then
          s(i) = abs(u(i+1)-u(i))-abs(u(i)-u(i-1))
          s(i) = s(i)/(abs(u(i+1)-u(i))+abs(u(i)-u(i-1)))
        else
          s(i) = 0.
        endif
80   continue
      do 90, i=0,n
        s1 = lambda
        s2 = .25*lambda*(1.-lambda)
        h(i) = s1*u(i) + s2*( (1.-s(i))*(u(i+1)-u(i))+
     c                        (1.+s(i))*(u(i)-u(i-1)) )
90   continue
      do 120, i=1,n
        u(i) = u(i)-h(i)+h(i-1)
120  continue
      u(0) = u(n)
      u(-1) = u(n-1)
      u(-2) = u(n-2)
      u(n+1) = u(1)
      u(n+2) = u(2)
500  continue
      write(9,*)
      write(9,1050)
      do 800, i=1,n+1
        write(9,1100) i, u0(i), u(i), abs(u(i)-u0(i))
800  continue
      close(unit=8)
      close(unit=9)
C...write simple file for plotting
      open(unit=10,file='vl2.plt')
      do 900, i=1,n+1
        write(10,1150) -1 + real(2*i-2)/real(n), u(i)
900  continue
      close(unit=10)
      stop
1000 write(9,*) '****Error reading data point number ', i,'****'
      close(unit=8)
      close(unit=9)
      stop
1050 format(4x,'N',11x,'INITIAL',12x,'VL2',11x, 'DIFFERENCE')
1100 format(i5,5x,f13.8,5x,f13.8,5x,f13.8)
1150 format(f14.9,5x,f14.9)
      end
发表于 2002-7-8 21:23:08 | 显示全部楼层
van leer 格式
Be careful with van Leer's scheme. A well-known problem of van Leer's
scheme is it generates a thicker boundary layer. For Euler problems,
it works great. Alternatives for van Leer'scheme are Roe and AUSM+.
AUSM+ is slow and more accurate. Roe is the most popular one and my
favorite one. It can easily be implemented into implicit code.
