查看: 4786|回复: 5
[求助]3D非结构网格如何实施壁面函数?
发表于 2002-4-4 12:11:42 | 显示全部楼层 |阅读模式
我看到Frink的论文中是这样处理的, 如图
但是这样划分网格比较麻烦,难道不能够完全采用普通的四面体实现壁面函数么?
我听说murthy发表在1997-1998年NHT,part b上的文章有相关内容,但是我找不到
希望高手帮助
 楼主| 发表于 2002-4-4 12:13:26 | 显示全部楼层
具体的论文名称是:
1.S R Mathur and J Y Murthy,
  a pressure-based method for unstructured mesh,
  NHT, Part B, 1997,31:195-197
  主要讲simple算法在unstructured grid 上实现的
2.S R Mathur and J Y Murthy,
  Pressure boundary conditons for incompressible flow
  using unstructured meshes
  NHT, Part B, 1997,32:283-298
3.J Y Murthy and S R Mathur,
  periodic flow and heat transfer using unstuctured meshes,
  Inter. J. Numer. Meth. in Fluids, 1997,25:659-677.
  后两篇是讲边条实现的。
哪位帮忙找找
发表于 2002-4-5 01:12:15 | 显示全部楼层
I tried to look for these articles for you , but I failed, maybe you could send e-mail Mrs.Jayathi Y.Murthy, here is her e-mail address
murthy@andrew.cmu.edu
发表于 2002-4-10 08:41:20 | 显示全部楼层
I found the first and last papers for you. I upload the last one now. For the first one, I have to go to the library to get it. The problem is how can I send you the copy.
 楼主| 发表于 2002-4-10 08:45:45 | 显示全部楼层
thanks.
发表于 2002-4-10 09:09:46 | 显示全部楼层
Do you still still need the first two papers? I can get a copy( it is a hard copy, not e-file) for you. But I don't know how to send it to you.
