查看: 2794|回复: 2
advard : i had used ground
发表于 2002-6-8 12:24:29 | 显示全部楼层 |阅读模式
i had used ground, but is not easy to explain well in here.
it need face to face to talk about how to use ground.
发表于 2002-6-9 08:59:48 | 显示全部楼层
where are you in?
发表于 2002-6-9 19:16:15 | 显示全部楼层
我试图用ground,后来一想灵活性还是不够,我现在想自己编程来对流场进行计算,使灵活性达到最高,希望有问题时能够不吝赐教。谢谢!
