查看: 2049|回复: 3
谁能帮我看一下结果
发表于 2003-6-9 08:36:36 | 显示全部楼层 |阅读模式
TIME STP=     1 SWEEP NO=   150 ZSLAB NO=     1 ITERN NO=     1
Whole-field residuals before solution
with resref values determined by EARTH
& resfac= 1.000000E-03
  variable   resref  (res sum)/resref
     P1     5.324E-08   3.881E+04
     U1     8.057E-07   4.086E+05
     V1     6.463E-08   1.650E+06
     W1     1.297E-07   8.406E+05
     KE     1.724E-07   7.598E+06
     EP     3.080E-04   7.441E+06
     TEM1   9.949E-03   1.571E+04
!! Zero nett sources are not printed !!!
Nett source of U1   at patch named: OB7      (INLET         ) = 1.427E-01
Nett source of U1   at patch named: OB8      (OUTLET        ) =-2.130E-01
pos. sum= 1.426792E-01 neg. sum=-2.129905E-01
nett sum=-7.031132E-02
Nett source of V1   at patch named: OB8      (OUTLET        ) =-1.065E-04
pos. sum= 0.000000E+00 neg. sum=-1.065309E-04
nett sum=-1.065309E-04
Nett source of W1   at patch named: OB8      (OUTLET        ) =-6.081E-04
pos. sum= 0.000000E+00 neg. sum=-6.081288E-04
nett sum=-6.081288E-04
Nett source of R1   at patch named: OB7      (INLET         ) = 1.427E-02
Nett source of R1   at patch named: OB8      (OUTLET        ) =-1.427E-02
pos. sum= 1.426793E-02 neg. sum=-1.426778E-02
nett sum= 1.508743E-07
Nett source of KE   at patch named: OB7      (INLET         ) = 3.567E-03
Nett source of KE   at patch named: OB8      (OUTLET        ) =-1.287E-02
Nett source of KE   at patch named: KESOURCE =-1.607E+00
pos. sum= 3.566982E-03 neg. sum=-1.619488E+00
nett sum=-1.615921E+00
Nett source of EP   at patch named: OB7      (INLET         ) = 2.437E-01
Nett source of EP   at patch named: OB8      (OUTLET        ) =-6.174E+00
Nett source of EP   at patch named: KESOURCE =-1.468E+04
pos. sum= 2.437437E-01 neg. sum=-1.469100E+04
nett sum=-1.469075E+04
Nett source of TEM1 at patch named: OB7      (INLET         ) = 4.201E+03
Nett source of TEM1 at patch named: OB8      (OUTLET        ) =-4.406E+03
Nett source of TEM1 at patch named: OD3      (TUNNEL1       ) = 1.536E+02
Nett source of TEM1 at patch named: OD4      (TUNNEL2       ) = 1.536E+02
pos. sum= 4.508603E+03 neg. sum=-4.406101E+03
nett sum= 1.025015E+02
spot values vs sweep or iteration number
    IXMON=    12    IYMON=     1    IZMON=     1 TIMESTEP=     1
   Variable    1 = P1     2 = U1     3 = V1     4 = W1     5 = KE
     Minval=  0.000E+00  0.000E+00  0.000E+00  0.000E+00  0.000E+00
     Maxval=  0.000E+00  0.000E+00  0.000E+00  0.000E+00  0.000E+00
     Cellav=  0.000E+00  0.000E+00  0.000E+00  0.000E+00  0.000E+00
   Variable    6 = EP     7 = TEM1
     Minval=  0.000E+00  2.000E+01
     Maxval=  0.000E+00  2.000E+01
     Cellav=  0.000E+00  2.000E+01
1.00 +....+....+....+....+....+....+....+....+....+....+
0.90 +                                                 +
0.80 +                                                 +
0.70 +                                                 +
0.60 +                                                 +
0.50 +                                                 +
0.40 +                                                 +
0.30 +                                                 +
0.20 +                                                 +
0.10 +                                                 +
0.00 7.7..7.7..7.7.7+.7.7+7..7+7..7+7.7.+7.7.7..7.7..7.7
      0   .1   .2   .3   .4   .5   .6   .7   .8   .9  1.0
the abscissa is      ISWP.  min= 1.00E+00 max= 1.48E+02
residuals vs sweep or iteration number
     Minval=  1.056E+01  1.293E+01 -8.596E+00 -7.436E+00  1.448E+01
     Maxval=  1.744E+01  1.647E+01  1.620E+01  1.503E+01  1.651E+01
     Minval=  1.583E+01  9.494E+00
     Maxval=  1.885E+01  2.346E+01
1.00 7.4..5.5..3.3..+....+....+....+....+....+....+....+
      .      4  4 4 4  4 4 4  4 4  4 4 4  4 4 4  4 4  4 4
0.90 + 5       5                                       3
      .           5 5  5 5                              .
0.80 +                    5  5 5  5 5 5                +
      .                                   5 5 5         .
0.70 +                                          5 5  5 +
      .                                                 5
0.60 +                                                 +
0.50 +                                                 +
0.40 +                                                 +
0.30 + 2  2 2  2                                       +
      . 1         2 2                                   .
0.20 +                2 2                              +
      .    6 6  6 6 6  6 6 6  2 2                       .
0.10 + 7  7 7  7 1           6 6  2 2                  +
      .           7 7  7 7 7  7 7  7 7 7  6 6 6  6      .
0.00 5....+....+....+....+....+....+....+7.7.7..7.7..7.7
SATLIT RUN NUMBER =   1 ; LIBRARY REF.=    0
Run completed at 17:02:00 on Thursday, 05 June 2003
MACHINE-CLOCK TIME OF RUN =    2639 SECONDS.
TIME/(VARIABLES*CELLS*TSTEPS*SWEEPS*ITS) = 5.630E-05
发表于 2003-6-9 10:05:31 | 显示全部楼层
谁能帮我看一下结果
帮你看什么呢,^_^
 楼主| 发表于 2003-6-9 10:21:12 | 显示全部楼层
谁能帮我看一下结果
当然是看看哪个系数收敛了?哪个没收敛?
请教改进方法,收敛银子应该往大调整,还是相反?
发表于 2003-6-9 15:28:46 | 显示全部楼层
谁能帮我看一下结果
haha ,收敛了好像,不过没有仔细分析你的结果,另外你的问题我也不太清楚。
