查看: 1662|回复: 1
请教,phoenics能算应力应变场吗
发表于 2003-11-10 16:33:55 | 显示全部楼层 |阅读模式
我现在在利用phoenics试着做温度场的分布,我想知道能否利用温度场的计算结果,做应力应变场,各位大拿给支个招!
发表于 2003-11-10 16:55:25 | 显示全部楼层
请教,phoenics能算应力应变场吗
有现成的例题,去看看。library case.
polis里面, 百科全书,solid stress and strain, 有相关介绍。
如果你使用3。5,那就可以作到
11. SFT (solid-stress + fluid-flow + Thermal analysis) developments
There have been two main developments in this area, namely:
1.The material properties which affect the stresses in solids, namely the Young's modulus, the Poisson's Ratio, and the coefficient of thermal expansion, are now allowed to vary arbitrarily throughout the domain of study.
Moreover the methods of specifying these properties have been brought into line with those used for the properties of fluids, as part of the reorganization mentioned in section 9.
2.Secondly, the treatment of bending moments has been improved by the introduction of an easy-to-solve additional equation.
