查看: 6552|回复: 6
请问phoenics如何安装?我怎么不会装!急死我了? (无内容)
发表于 2002-4-24 03:44:26 | 显示全部楼层 |阅读模式
发表于 2002-4-24 15:23:53 | 显示全部楼层
什么版本?我告诉你安装,一般在根目录下安装!
发表于 2002-4-29 10:36:41 | 显示全部楼层
我就找到一个3.2,你有新的么?我装在d盘,怎么是个空目录啊?
发表于 2002-4-30 15:53:06 | 显示全部楼层
copy
发表于 2002-5-3 10:50:29 | 显示全部楼层
请教高手,如何弄到phoenicx3.2的密码.
发表于 2002-5-5 20:26:01 | 显示全部楼层
一般来说,很难弄到密码。但是,phoenics 3.2 版本
的有相应的 Crack 文件。比如像其可执行文件 PVREXE 就
有一个 pvrexe_crk.exe。执行 pvrexe_crk.exe 后就好了。
这个版本的网上应该能找到。
我就是装了这个版本的
发表于 2002-5-6 13:13:35 | 显示全部楼层
其实Phoenics最新版本是3.4网络版的。
Phoenics软件的安装解密过程如下,希望对大家有所帮助!
                        Unlocking PHOENICS
PHOENICS is locked/unlocked using a machine-dependent unlocking string present in the CONFIG file in the directory phoenics\d_allpro.
For PCs, PHOENICS can be unlocked using the id of a dongle, or by using the hard disk Volume Serial Number. A dongle is more flexible since it can be moved from PC to PC, thus allowing PHOENICS to be used on any one PC at a time.
PHOENICS is normally supplied with a dongle, and with an unlocking string for a dongle already present in the CONFIG file.
If a user does not have a dongle, or cannot use one, then it will be necessary to inform CHAM of the hard disk Volume Serial Number so that a suitable unlocking string can be supplied.
The Volume Serial Number of a disk can be obtained by typing the command ‘Vol’ at the DOS command prompt. Under Windows, this can be done from an MS-DOS window.
For UNIX based computers, the CPU dependent ID string (i.e. unlocking string) will be supplied by CHAM on receipt of the CPU (or equivalent) identifiers for each computer or processor on which PHOENICS is to be run.
An example of the unlocking string and its location in the CONFIG file is shown below (the example is not currently valid). The unlocking string consists of the line starting with the text 'ID='
* ------ The configuration file CONFIG for PHOENICS version 3.4 ------
ID=:9(L8P3Y)P5ABG1AIOA/2D:SF dongle March 2001
SITE= CHAM
SATPRE=\phoenics\d_satell\
EARPRE=\phoenics\d_earth\
PHOPRE=\phoenics\d_photon\
AUTPRE=\phoenics\d_photon\
The Node Id of a PC is either the dongle number (currently 10793) or the hard disk Volume Serial Number.
The Node Id is displayed when a PHOENICS program fails due to expiry of an unlocking string, and is on the line following the text
‘ The ID of this node is . . . . .’
On Windows systems, this message is written to the file luout in the current working directory.
The Node Id should be recorded on the unlocking request form provided and returned to:
Installation Section Tel: 020 8947 7651
CHAM, Fax: 020 8879 3497
Bakery House e-mail: bmz@cham.co.uk
40 High Street,
Wimbledon
London SW19 5AU
