查看: 2039|回复: 2
SOS! 请高手看看我的Q1,几个问题请教!
发表于 2004-1-6 09:18:35 | 显示全部楼层 |阅读模式
我做的是一个开口的冷柜,详细情况见Q1文件,现在问题是算得结果不对,气流应该从inlet 出来,流向outlet,请问outlet应该如何设置? 如果用fan代替inlet,如何设定出口温度?
第二是外边的大空间是环境,边界条件是速度为0,梯度为0,使用却省边界行不?另外请问怎么设定温度呢(即模拟不同环境温度)?
以上温度请高手给与指点,也可直接在Q1文件中修改,发给小弟,不胜感激!
soloknight@etang.com
发表于 2004-1-6 17:35:51 | 显示全部楼层
Q1?
 楼主| 发表于 2004-1-6 20:27:00 | 显示全部楼层
竟然无法贴上附件,唉!贴在下面把!
TALK=T;RUN( 1, 1)
   Q1 created by VDI menu, Version 3.3, Date 10/02/00
CPVNAM=VDI;SPPNAM=Core
IRUNN   =       1 ;LIBREF =       0
  Group 1. Run Title
TEXT(No title has been set for this run.     )
  Group 2. Transience
STEADY  =    T
  Groups 3, 4, 5  Grid Information
    * Overall number of cells, RSET(M,NX,NY,NZ,tolerance)
RSET(M,200,150,1)
    * Set overall domain extent:
    *        xulast  yvlast  zwlast
            name
XSI= 2.200000E+00; YSI= 1.500000E+00; ZSI= 1.785000E+00
RSET(D,CHAM    )
  Group 6. Body-Fitted coordinates
  Group 7. Variables: STOREd,SOLVEd,NAMEd
ONEPHS  =    T
    * Non-default variable names
NAME(149) =EPKE ; NAME(150) =TEM1
    * Solved variables list
SOLVE(P1  ,U1  ,V1  ,TEM1)
    * Stored variables list
STORE(EPKE)
    * Additional solver options
SOLUTN(P1  ,Y,Y,Y,N,N,Y)
SOLUTN(TEM1,Y,Y,Y,N,N,Y)
TURMOD(KEMODL)
  Group 8. Terms & Devices
TERMS (TEM1,Y,Y,Y,Y,Y,Y)
  Group 9. Properties
SETPRPS(1,  0)
RHO1    = 1.189000E+00
PRESS0  = 1.000000E+05
TEMP0   = 2.730000E+02
CP1     = 1.005000E+03
ENUL    = 1.544000E-05
DVO1DT  = 3.410000E-03
PRNDTL(TEM1) = -2.580000E-02
  Group 10.Inter-Phase Transfer Processes
  Group 11.Initialise Var/Porosity Fields
FIINIT(EPKE) =  1.000000E+00
   No PATCHes used for this Group
INIADD  =    F
  Group 12. Convection and diffusion adjustments
  Group 13. Boundary & Special Sources
PATCH (BUOYANCY,PHASEM,0,0,0,0,0,0,1,1)
COVAL (BUOYANCY,U1  , FIXFLU      , GRND3       )
COVAL (BUOYANCY,V1  , FIXFLU      , GRND3       )
BUOYA   = 0.000000E+00 ; BUOYB =-9.810000E+00
BUOYC   = 0.000000E+00
BUOYD   = 3.410000E-03
BUOYE   = 2.000000E+01
EGWF    =    T
  Group 14. Downstream Pressure For PARAB
  Group 15. Terminate Sweeps
LSWEEP  =     500
RESFAC  = 1.000000E-05
  Group 16. Terminate Iterations
  Group 17. Relaxation
RELAX(P1  ,LINRLX, 1.000000E+00)
RELAX(U1  ,FALSDT, 5.000000E-01)
RELAX(V1  ,FALSDT, 5.000000E-01)
RELAX(KE  ,LINRLX, 5.000000E-01)
RELAX(EP  ,LINRLX, 5.000000E-01)
RELAX(TEM1,FALSDT, 1.000000E+04)
KELIN   =       3
  Group 18. Limits
VARMAX(U1  ) = 1.000000E+06 ;VARMIN(U1  ) =-1.000000E+06
VARMAX(V1  ) = 1.000000E+06 ;VARMIN(V1  ) =-1.000000E+06
  Group 19. EARTH Calls To GROUND Station
USEGRD  =    T  ;USEGRX =    T
GENK    =    T
ASAP    =    T
LSG3    =    T
CSG3    ='FGEM'
  Group 20. Preliminary Printout
ECHO    =    T
  Group 21. Print-out of Variables
OUTPUT(P1  ,Y,Y,Y,N,Y,Y)
OUTPUT(U1  ,Y,Y,Y,N,Y,Y)
OUTPUT(V1  ,Y,Y,Y,N,Y,Y)
  Group 22. Monitor Print-Out
IXMON   =      11 ;IYMON  =      29 ;IZMON  =       1
NPRMON  =  100000
NPRMNT  =       1
TSTSWP  =      -1
  Group 23.Field Print-Out & Plot Control
NPRINT  =  100000
ISWPRF  =       1 ;ISWPRL =  100000
  Group 24. Dumps For Restarts
NOWIPE  =    T
GVIEW(P,2.064056E-01,0.000000E+00,-9.784666E-01)
GVIEW(UP,0.000000E+00,1.000000E+00,0.000000E+00)
> DOM,    SIZE,        2.200000E+00, 1.500000E+00, 1.785000E+00
> DOM,    MONIT,       5.250000E-01, 2.951250E-01, 8.925000E-01
> DOM,    SCALE,       1.000000E+00, 1.000000E+00, 1.000000E+00
> DOM,    SNAPSIZE,    1.000000E-02
> GRID,   RSET_X_1,     20, 1.000000E+00
> GRID,   RSET_X_2,      3, 1.000000E+00
> GRID,   RSET_X_3,     10, 1.000000E+00
> GRID,   RSET_X_8,     10, 1.000000E+00
> GRID,   RSET_X_10,     10, 1.000000E+00
> GRID,   RSET_Y_1,     20, 1.000000E+00
> GRID,   RSET_Y_4,      6, 1.000000E+00
> GRID,   RSET_Y_5,      6, 1.000000E+00
> GRID,   RSET_Y_6,     10, 1.000000E+00
> GRID,   RSET_Y_7,     10, 1.000000E+00
> GRID,   RSET_Y_8,      8, 1.000000E+00
> GRID,   RSET_Y_9,      6, 1.000000E+00
> DOM,    RELAX,       5.000000E-01
> OBJ1,   NAME,        XIANGTI
> OBJ1,   POSITION,    1.000000E+00, 0.000000E+00, 0.000000E+00
> OBJ1,   SIZE,        9.889910E-01, 7.748379E-01, 1.785000E+00
> OBJ1,   CLIPART,     duantou
> OBJ1,   ROTATION24,        0
> OBJ1,   TYPE,        BLOCKAGE
> OBJ1,   MATERIAL,      139
> OBJ1,   ADIABATIC,     0.000000E+00, 0.000000E+00
> OBJ2,   NAME,        JIYABAN
> OBJ2,   POSITION,    1.907800E+00, 6.206733E-01, 0.000000E+00
> OBJ2,   SIZE,        3.620001E-02, 7.442005E-02, 1.785000E+00
> OBJ2,   CLIPART,     jiyaban
> OBJ2,   ROTATION24,        0
> OBJ2,   TYPE,        BLOCKAGE
> OBJ2,   MATERIAL,      100
> OBJ2,   ADIABATIC,     0.000000E+00, 0.000000E+00
> OBJ3,   NAME,        DINGQIAO
> OBJ3,   POSITION,    1.864200E+00, 6.950933E-01, 0.000000E+00
> OBJ3,   SIZE,        7.979999E-02, 5.090668E-02, 1.785000E+00
> OBJ3,   CLIPART,     dingqiao
> OBJ3,   ROTATION24,        0
> OBJ3,   TYPE,        BLOCKAGE
> OBJ3,   MATERIAL,      100
> OBJ3,   ADIABATIC,     0.000000E+00, 0.000000E+00
> OBJ4,   NAME,        INLET
> OBJ4,   POSITION,    1.906000E+00, 6.130930E-01, 0.000000E+00
> OBJ4,   SIZE,        0.000000E+00, 4.100000E-02, 1.785000E+00
> OBJ4,   CLIPART,     cube3t
> OBJ4,   ROTATION24,        1
> OBJ4,   TYPE,        INLET
> OBJ4,   PRESSURE,      0.000000E+00
> OBJ4,   VELOCITY,     -5.000000E-01, 0.000000E+00, 0.000000E+00
> OBJ4,   TEMPERATURE,  -2.300000E+01
> OBJ4,   TURB-INTENS,   5.000000E+00
> OBJ5,   NAME,        INLETUP
> OBJ5,   POSITION,    1.906000E+00, 6.540930E-01, 0.000000E+00
> OBJ5,   SIZE,        0.000000E+00, 4.100000E-02, 1.785000E+00
> OBJ5,   CLIPART,     cube3t
> OBJ5,   ROTATION24,        1
> OBJ5,   TYPE,        INLET
> OBJ5,   PRESSURE,      0.000000E+00
> OBJ5,   VELOCITY,     -2.000000E-01, 0.000000E+00, 0.000000E+00
> OBJ5,   TEMPERATURE,  -2.300000E+01
> OBJ5,   TURB-INTENS,   5.000000E+00
> OBJ6,   NAME,        BEIFENGB
> OBJ6,   POSITION,    1.906000E+00, 2.000000E-01, 0.000000E+00
> OBJ6,   SIZE,        2.000000E-03, 4.130000E-01, 1.785000E+00
> OBJ6,   CLIPART,     cube4
> OBJ6,   ROTATION24,        1
> OBJ6,   TYPE,        BLOCKAGE
> OBJ6,   MATERIAL,      100
> OBJ6,   FIXED_TMP,     0.000000E+00,-2.300000E+01
> OBJ7,   NAME,        HUIFENGB
> OBJ7,   POSITION,    1.104000E+00, 2.000000E-01, 0.000000E+00
> OBJ7,   SIZE,        2.000000E-03, 3.800000E-01, 1.785000E+00
> OBJ7,   CLIPART,     cube4
> OBJ7,   ROTATION24,        1
> OBJ7,   TYPE,        BLOCKAGE
> OBJ7,   MATERIAL,      100
> OBJ7,   FIXED_TMP,     0.000000E+00,-1.800000E+01
> OBJ8,   NAME,        BOTTOM
> OBJ8,   POSITION,    1.106000E+00, 2.000000E-01, 0.000000E+00
> OBJ8,   SIZE,        8.000000E-01, 2.000000E-03, 1.785000E+00
> OBJ8,   CLIPART,     cube4
> OBJ8,   ROTATION24,        1
> OBJ8,   TYPE,        BLOCKAGE
> OBJ8,   MATERIAL,      100
> OBJ8,   FIXED_TMP,     0.000000E+00,-2.300000E+01
> OBJ9,   NAME,        OUTLET
> OBJ9,   POSITION,    1.030000E+00, 5.000000E-01, 0.000000E+00
> OBJ9,   SIZE,        7.400000E-02, 0.000000E+00, 1.785000E+00
> OBJ9,   CLIPART,     cube12t
> OBJ9,   ROTATION24,        1
> OBJ9,   TYPE,        OUTLET
> OBJ9,   PRESSURE,      0.000000E+00
> OBJ9,   TEMPERATURE,  -1.026000E+04
> OBJ9,   COEFFICIENT,   1.000000E+03
> OBJ9,   TURBULENCE,   -1.026000E+04,-1.026000E+04
> OBJ9,   OBJECT-SIDE,   1.000000E+00
M
STOP
