查看: 2568|回复: 1
[求助]CFX-Slover运算时出现这样的错误提示,咋办?
发表于 2005-7-11 15:27:27 | 显示全部楼层 |阅读模式
|                     ****** Notice ******                           |
| Newtons method failed to converge in  100 iterations.  This        |
| occured while computing the following variable:                    |
| Variable Name  : Temperature                                       |
| Location Name  : Middle                                            |
| Mesh location  : VERTICES                                          |
| Mesh entity    :                                                   |
| Last 3 Changes :  1.89331E-01  1.89331E-01  1.89331E-01            |
| Tolerance      :  1.0000E-02                                       |
| The Newton iteration was either slowly converging or has stalled.  |
| The solver will continue with the variable set as it was on the    |
| final iteration.  If this situation continues you might try        |
| increasing the number of iterations allowed for Newtons method.    |
| This can be changed by setting one of the parameters:              |
| Temperature : "Constitutive Relation Iteration Limit"              |
| Pressure    : "Newton Pressure Iteration Limit"                    |
| for your mixture using the definition file editor.                 |
| ERROR #004100018 has occurred in subroutine FINMES.                |
| Fatal overflow in linear solver.                                   |
这是瞬态计算,该怎么改啊,是增加每个时间步长下的迭代次数么?
发表于 2005-7-12 21:57:48 | 显示全部楼层
我也遇到了这个问题,哪位高手知道啊?
